Need help with bricked h96pro plus
    Hi, yesterday i try to upload my h96pro plus 3/32gb with SD. This start to upload and after 2 seconds led red ON and don’t turn ON anymore. I read that need upload with usb cable and join pins marked in image, but with img need to upload? Those pins are correct?
    regards
    Your pin(marks)..what is he pin count from the start triangle(1st Pin). Most likely Pins 29 and 30..
    Check your vendors website...or try to ask(E-mail/forums) for original firmware.
    You could Google T92 v.10 16445 for firmware options.
    https://forum.freaktab.com/forum/tv-...n-unbrick-help
    G-Luck
      Thanks for reply. But my tv box is old and don’t know id the seller will reply
        hi. I try to make all as tutorial and allways have the same error. I try to use the USB neard to power adapter but the only USB where windows detect it is in USB 1 neard to ethernet port. Any idea?
          USB port nearest power supply-- yes
          Try another USB -A <> USB -A cable.
          If you find a proper firmware.
          * When you have shorted the pins...Load firmware and Press start on the Burn Tool
          * Then you hold reset button and plugging in power supply at the same time.
          * It may start to flash immediately.
