Black 4GB DDR4 +64GB EMMC
Amlogic S905X3, 2.4GHz + 5.0GHz Dual-band WiFi, 100Mbps, USB3.0, BT4.2, H.264, H.265, Support 8K 24fps
"First budget S905x3 that might actually be worth buying..."
From Gearbest:
As Found:
Enjoy a more beautiful image video
EACHLINK X3 MINI Android 9.0 smart 4K TV box comes with Amlogic S905X3 Quad-core CPU and ARM G31 MP2 GPU, making it run more smoothly. Support 8K UHD resolution, you can see more detailed and more beautiful images.
Main Features:
?Amlogic S905X3 Quad-core CPU + ARM G31 MP2 GPU
Comes with the high-performance CPU + GPU, making the N5 Plus TV box run fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games, which improve the running speed and enhances the image processing capability.
?Android 9.0 OS
Adapted Android 9.0 operation system for strong compatibility, it is compatible with more software, games, and applications to improve user experience.
?HEVC H.264 VP9 AVS2-P2
Various video decoding can save more bandwidth resources, let you watch the 8K movie smoothly.
?8K UHD Resolution
Support multi-video decoder up to 8K 24fps, 4K x 2K @ 60fps + 1 x 1080P @ 60fps, which provides much more detailed and better-looking image.
?Support 2.5 inch 4TB HDD / SSD Hard Drive Interface
Whether you are home, work, life, games and other storage needs, easily meet your storage needs. ( Not included in the package )
?4GB RAM + 32GB / 64GB ROM
4GB RAM + 32GB / 64GB ROM storage memory allows you to display HD video smoothly and download massive resources from the Internet, it is large enough to store large numbers of movies and Applications and browse the web, etc.
?USB 3.0
The transfer speed is theoretically 10 times faster than USB2.0. You can quickly transfer movies, images and other resources from USB drives or mobile devices to the TV box for playing.
Gearbest
