[Step by Step Tutorial] LibreElec on H96 Max+ *** Also IR Remote support ***
    Firstly I would like to thank all user who have made a contribution in support of RK3328 device, in particular:
    balbes150, @hexdump from Armbian Forum, @easyb From Armbian Forum, @ amirul From Armbian Forum and LE community.
    What you need:
    1 USB stick: at least 1 gb
    1 SD Card : strongly suggespted at least 4 gb
    Balena Etcher: https://www.balena.io/etcher/
    LibreElec custom image for H96 Max+
    : https://mega.nz/#!IxYXFIbb!DCiQiwYLK...-dyQ8IUDnDl2nA
    referred imaginatively by me as "Libre_Elec H96 Max+ _Crossover"
    IR Remote fix: https://mega.nz/#!hpZlxAzb!FaqEvNF_T...iwQmbXdOF7As3U
    Let's Start
    Install and open Balena Etcher ----> click on "select image" and choose
    Libre_Elec H96_Max+ _Crossover.img
    Instert usb stick and SD card in your pc.
    -I suggespt to delete all partitions on these units , make a backup before doing it-
    Click on "Select Target" and choose: USB stick and SD card
    Click on
    "Flash!"----> wait for FINISH.
    Now insert USB stick and SD card in your H96 Max+, connect HDMI cable to TV, connect power supply cable.
    Now you can read on screen:
    "PARTITION RESAZING IN PROGRESS" , wait till the device is rebooted.
    After the reboot you can see the home screen
    of KODI, complete first setup using a usb mouse.
    Wait 5 minutes, then power off the device using the icon in KODI home screen.
    Remove power supply cable, remove USB stick, keep SD card inserted in H96 Max+.
    Power on the device,leave work the interafce till you see KODI HOME.
    Now you have succesfully installed LibreElec on SD card
    How to make IR Remote working:
    Open IR_Remote_fix_by_easyb.zip,----> extract: [h96mp , rc_maps.cfg] in a free USB stick.
    Open settings in KODI,----> click on File Manager ,----> click on Add source,----> set same as picture and click ok.
    Click image for larger version  Name:	1.jpg Views:	0 Size:	112.1 KB ID:	790386
    Insert your usb stick in H96 Max+.
    You have now a situation like a next picture, you can see 2 different columns. -my usb stick is named "USB_STICK"-
    In left column open your
    USB stick clicking on her name,
    in right colum open .config folder clicking on it.
    You must click one for one on two files : [h96mp , rc_maps.cfg] in left column, till their names become green,
    ----> right button of your mouse and click on copy,----> Confirm. Results in next picture
    In the right column click and enter in rc_keymaps folder, reselect two files in left column, they become green, right button of your mouse, click on copy, Confirm. Results in next picture
    Reboot device. You have now a working IR Remote.
    HDMI AUDIO: works
    IR Remote: works
    Wifi usb dongle: works
    bluetooth usb dongle: works
    ON/OFF Led Indicator: works
    CEC: not tested
    Final conclusions: what I've done, and why:
    I have assembled the image, but the credits belongs to others.
    I chose to use:
    The super system: LE 9.80 kernel 4 by balbes150: that support usb wifi and bluetooth dongles.
    The easyb dtb to be able to offer compatibility with HDMI AUDIO and have ON/OFF LED that works.
    The u-boot component of LE 9.1 generic official image, beacuse the easyb dtb doesn't work with balbes150 u-boot. i don't know why.
    IR Remote Fix by easyb: to make remote control works.
    In the guide there could be inaccuracies regarding the terms used, forgive my lack of knowledge.
    There are LibreElec features that I haven't tested yet, any error report or correction report is welcome
    As far as I remember rk3328, if the SD card is supported in DTB, the first start does not require a USB drive, everything should work with one SD card at once.
      Ok thank you balbes, when i have free time i make an attempt to give a confirmation to users.
      I think anyway that the dbt of easyb and perhaps also the other dtb for this device; needing to be improved as far as video support is concerned, the quality is not great when playing movies online.
