gt king s922x cant do wireless update
can you try updating it manually with the ZIP or worst case with the image file which you can flash with burn tool?
Just get TWRP loaded via sd card first so you can do a data partition backup if required.
Make sure you get the correct firmware for your serial number.
SN:922X & SN:95X2 = LPDDR4
SN:B922 = DDR4
http://www.bee-link.com/forum.php?mo...extra=page%3D1
There are currently 1509 users online. 0 members and 1509 guests.
