Can anybody help me locate where this "Gi" logo is located in the firmware? because it's not on the wallpaper/background of the launcher. i have already edited the launcher apk and changed the background but that logo is always there. i cannot find it in any of the PNGs or JPGs that is inside the launcher apk. it could be text or in xml, have no idea. please help. thanks a lot.
Gi Lunn Rom remove Gi homescreen logo
Hi everyone.
Can anybody help me locate where this "Gi" logo is located in the firmware? because it's not on the wallpaper/background of the launcher. i have already edited the launcher apk and changed the background but that logo is always there. i cannot find it in any of the PNGs or JPGs that is inside the launcher apk. it could be text or in xml, have no idea. please help. thanks a lot.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
why are you not install another Launcher ???
good luck / gefattern
yes sir, i also try different launcher. just very curious on how to get to this "Gi" logo that appears with this stock Gi Launcher.. do you have an idea?
sorry i dont know how to , on AML ,
but for this you must have "root" or Tool on PC , to change it ,
Hi ,
this amlogic device of mine came prerooted out of tje box, and mostly, if not all, of the firmwares for this s905w device are already rooted. i use root explorer to push the system files since adb is not working on this current firmware that i am using, for some reason i dont know. i already modified this launcher if you can notice the background and icons, and this rom using the amlogic customization tool. i just want to figure out where this "Gi" image is located.
not sure , maybe it is inside the "kernel" or somewhere else , but you can find many helpful Infos when you read relevant Threads about similar Problems ,
There are currently 2637 users online. 0 members and 2637 guests.
