h96 max + RK3328 box will not turn on
h96 max + RK3328 box will not turn on. red light only. tried 2 other working power supplies and no change. Used factory tool 1.6 to try to upload new firmware and keep getting loader fail.... made a sd boot disk and can get it to boot to recovery but cannot get it to update firmware from the sd either.Tags: None
Originally posted by bsparkin View Posth96 max + RK3328 box will not turn on. red light only. tried 2 other working power supplies and no change. Used factory tool 1.6 to try to upload new firmware and keep getting loader fail.... made a sd boot disk and can get it to boot to recovery but cannot get it to update firmware from the sd either.
Hi I am new to these TVboxes and need some help!! I have a H96Max+ RK3328 Ram 4G Rom 64 Android 9. I accindently removed? Kodi and after that the TVbox will not start, i only have a black screen in my TV and the box will not connect. I have tried to update the firmware, but got some errors, and now the box seems DEAD. It will
Originally posted by Rashid1122 View Posti want kernel.img for rk3328, h9max plus 4gb 64gb with android 9.0
for this you can use AndroidTool 2.35 or above , to unpack the hole .img File , think third Tab in Tool , then you have your kernel & all other parts ,
i think it has to do with "uboot" , but i am no Pro
good luck / gefattern
hi thanks for reply, got your point, everything completed smoothly, but still i am in maskrom mode and unable to get out my device from maskrom mode, and still device is not working with just red light on it. please guide me what to do now to get out from maskrom mode, device is now detected in maskrom automatically without pressing reset button.
There are currently 1527 users online. 1 members and 1526 guests.
