TOPRECIS T8 4500 Lumens 1080p projector android 7.1.2 - Netflix issue
    Hi there Guys,
    I hope you can help me with this,
    I got this projector from Banggood that is honestly a very nice deal, amazing picture quality and quite silent.
    The only problem that I'm facing is with the android version that should be 7.1.2, none of the netflix version work on it,
    I can't really find out the hardware, from what I see is the 905(?) from amlogic.
    I tried to install a new firmware with the classic burning tool via usb, I cannot find a way to put the projector in recovery mode to actual finish the whole process, it has no reset buttons only the normal on/off up down source ect.
    Does any of you have any suggestions, I already tried to reboot in recovery mode with apps like Termus but says access denied.
    Thanks for your help
    Hi buddy, any https://tellgamestop.vip/ follow up with this? Facing similar https://mycfavisit.me/ issue at my end too
    Regards,
    Jovitit Smith
      Has no reset buttons only the normal on/off up down source ect.
