Beelink GT1 MINI (B95X) bricked?
    Hi, my first time here. Please be gentle.
    I've got a Beelink GT1 MINI s/n B95X...
    In an attempt to make HBO Go work on my GT Mini, I used an unroot program. Unfortunately, now when I try to boot the box it gets stuck on the "please wait..." screen. So, I tried to do a factory reset. Toothpick, then plug in power. I selected "Wipe data/ factory reset" and it still gets stuck on "please wait.."I even let it run all night like that to see if it would boot and it never booted up.
    I've reset it 10+ times and always the same result, "please wait..."
    My Win 10 computer won't recognize the GT1 MINI. I've tried installing, re-installing the driver. I even put it in test mode and that didn't work. I have had minimal success with burning to SD card. I've been able to burn GT1Mini_AT_V1.0A_9.0_B905.img to an SD card. When I pop it into the GT1 Mini and select "update" from EXT" in recovery mode I just get a bunch of errors, "Failed to mountsdcard ... (Invalid argument)
    At this point I'm getting very discouraged. Can someone please reach out to help me? I really need this box to work and I've spent a lot of time trying to fix it, but nothing is working. It's still under warranty if that helps.
    My thread at the Beelink forum:
    Sorry about the double post. Not sure how that happened.
    • gefattern
      gefattern commented
      Editing a comment
      already deleted / gefattern
    Thank you!
      I got it sorted out. I'm still looking for a way to get the sound to work on my Beelink G1 Mini. All my other movie apps work fine, but I'm told it doesn't work because the G1 Mini is rooted.
