(ROM) Minixfreak_OS ReMastered
    Changelog
    Dec 1 2019
    -Based On Beelink 906P0 Firmware
    -True Android TV Experience
    -Tweaked SystemUI
    -Added More Remotes Layouts
    -Tweaked Wifi Drivers
    -Ported Slimhouse Settings (Thank You Slimhouse) 4PDA
    -Voice Search
    -Updated Gapps
    -SuperSU
    -AutoFrameRate App (Thanks 4PDA)
    -Stock Recovery
    -Add AppDrawer Custom Banner(Thanks 4PDA)
    -Added Shortcuts for Speedtest & Google Chrome
    -Added AptoideTV
    -Fixed Some Permissions
    -Add Bluetooth Mobile To Settings
    -SmartYoutube (No Ads)
    -IPTV Reboot issue Fixed
    -Updated Codecs
    -Other Things I Also did but forget everything
    -Framework Modded for my needs and ATV features
    Bugs
    -You Tell Me
    Tips
    -Allowing permission to an app will shut down the app but just open it again and you're good to go
    -Get rid of supersu notifications turn off under the supersu settings
    -Autoframerate might show no signal even if u allow it on root just go to settings and turn on it might be turned off under its settings
    Downloads
    GTKING DDR4
    GTKING LPDDR
    GTKINGPRO REV1
    GTKINGPRO REV2
    Coming soon
    Builds are uploading as we speak be patient , im still working on a few other builds ..... any other companies want me to make AndroidTV just PM
    Which device?:
      Which device?:
      Gt king both versions ... Gt king pro both versions ... Gt1mini both versions ... Gt1mini2 and h96 max x2
        Been very busy making this firmware alot of debugging ajd testing and countless houra so hope everyone enjoys them im just trying to figure out file storage right now ... My mega and mediafire both full .... So i have to delete things or look for another option
          That is absolutely amazing. I can only imagine the hours that you have put into that. Looking forward to those firmwares. Thanks
            Thanks for your hard work minixfreak
            Any idea when automatic frame rate switching will be integrated into the firmware without root being needed?
              Im working on magisk directly into the firmware
                Originally posted by minixfreak View Post
                Im working on magisk directly into the firmware?
                I am assuming that will enable you to hide root?
                  Yes
                    Yes?
                    That sounds fantastic!
