Is the CPU the H96 Max Android TV box of rk3318 connected with WiFi or wired Ethernet?
I'm not sure what kind of connection is better. Some people say WiFi is more convenient. Some people say wired Ethernet is less likely to get stuck. Personally, I don't think it makes any difference. How about you? H96 Max TV box is very good in picture quality. 4K HD video output, with the feeling of cinema, is still worth it.Last edited by Florentino; 05 December 2019, 07:02.Tags: None
Originally posted by Florentino View PostI'm not sure what kind of connection is better. Some people say WiFi is more convenient. Some people say wired Ethernet is less likely to get stuck. Personally, I don't think it makes any difference. How about you? H96 Max TV box is very good in picture quality. 4K HD video output, with the feeling of cinema, is still worth it.
Make sure the device you buy has 1000mbps ethernet and not just cheap 100mbps ethernet.
But you must lay cable from your router to the tv box which might be inconvenient if it's very far away.
Wifi should work well but not for very high bit-rate videos, but if your device only has 100mbps ethernet(H96 Max) then wifi will be faster.
Ethernet is more stable and faster over the long run.
There are currently 1596 users online. 1 members and 1595 guests.
