According to version: GTKing_PRO_906P0_wol_20191023.img
Android version: 9
Motherboard configuration:
Main control: S922X -H
Memory: DDR4 4G
Storage: EMMC 64G
WIFI and BT: AP6356S
Boron: 1000M
This firmware is only applicable to machines with SN code C92X and is not compatible with other machines with SN code version
Flash tutorials and tools:
Firmware:
modify:
1. Add a system switch (long press the power button on the remote control, the system switch options will appear)
2.Fix the problem that the USB icon of ui does not show usb when plugged in with SD card or u.
3.Fix the problem that the external keyboard cannot be turned off when the external keyboard is plugged in
Beelink Official:www.bee-link.com
Service email: [email protected]
Beelink Youtube: http://t.cn/RDp97bi
Beelink Facebook:https://www.facebook.com/Beelink.fans
Beelink instagram:https://www.instagram.com/beelink_official/
