what custom firmware is used for Pendoo X6 PRO Android TV Box 4GB RAM 32GB ROM
Originally posted by sssolider2 View Postwhat custom firmware is good for Pendoo X6 PRO Android TV Box 4GB RAM 32GB ROM
As as far as custom firmwares, the only one I would recommend would trying would be the LibreELEC nightly image for the TX6, which will only work if the devices are indeed identical hardware.
If if you are looking for a custom Android Firmware, then you most likely will not find one unless the guys at 4pda have succeeded in modifying Allwinner ROMs with Pie.
i have the same boxes pendoo x6 pro they are indeed tx6 knockoffs.. this firmware works on mine https://forum.freaktab.com/forum/tv-...al-android-7-0
i also gave the latest pendoo firmware a shot (https://chinagadgetsreviews.com/down...ro-tv-box.html) , and although it was an improvement from the firmware that came on the box, it still didn't solve my issues of choppy video playback.
Originally posted by pcdude28259 View Posti have the same boxes pendoo x6 pro they are indeed tx6 knockoffs.. this firmware works on mine https://forum.freaktab.com/forum/tv-...al-android-7-0
There are currently 2438 users online. 0 members and 2438 guests.
