Victsing ViTV-2 tv box does not open. What can I do?
I bought the Victsing ViTV-2 tv box. 2gb ram 16gb rom. Rockchip 3368 64Bit Octa Core 28nm. Android text is displayed and then the device restarts itself. I format, but it's not fixed. How can I solve the problem, can I do reinstall software or something?
Tags: None
Originally posted by kartalim2551 View PostI bought the Victsing ViTV-2 tv box. 2gb ram 16gb rom. Rockchip 3368 64Bit Octa Core 28nm. Android text is displayed and then the device restarts itself. I format, but it's not fixed. How can I solve the problem, can I do reinstall software or something?
https://drive.google.com/open?id=1CK...czztAJ_ROW9gtu
you did what ??? format what ??? ,
you must flash new , with Stockrom ,
good luck / gefattern
There are currently 3582 users online. 1 members and 3581 guests.
