[ROM] Ugoos X3 ATV_by_Sasvlad ( AndroidTV 9.0 )
    Update: [ROM] Ugoos X3 Android TV by Sasvlad v.0.3.6
    Dear friends, I present to your attention my new hybrid for ATV lovers.
    Many thks to UGOOS for sending me the device to play.
    1. All the benefits and convenience of the AndroidTV interface for Remote Control are present.
    2. For those who like to work with a mouse, there is a Status and a Navigation bars, imperceptible for those who love the Remote, not the mouse.
    3. You can also use the browser. An alternative TV-Market is installed in addition to the reduced ATV Market.
    To increase the speed of work, I deleted everything that can be done without.
    Changelog v.0.2.5:
    • 1. Picture optimization are disabled by default and added switcher (Playback settings)
    • 2. Added experimental video picture settings (Playback settings)
    • 3. Added TWRP-Recovery by Sasvlad
    • 4. Notifications from Android TV Remote Service are disabled by default
    • 5. Enabled long press and double tap events for HOME button
    • 6. Added confirm dialog to display color settings
    • 7. Added some key layout files
    • 8. Redesigned PowerMenu application. Now it is translucent. Added the ability to display its buttons on the main screen, assigning commands to buttons. 9. The new App Drawer, the appearance is improved for Android TV. Design borrowed from AmazonFire.
    Changelog v.0.2.7
    • 1. Fixed audio clicks in AV port
    • 2. Added mouse settings to TvSettings
    • 3. Added experimental ability use mouse as touch input
    • 4. Video Picture Settings. Disabled system automatic frame rate function
    • 5. Video Picture Settings. Fixed bugs of hue setting
    • 6. Video Picture Settings. Removed sharpness setting
    • 7. Video Picture Settings. Added setting for disabling all video effects and optimizations
    • 8. Fixed some buttons in Chrome
    • 9. SambaServer. Changed names of storages
    • 10. Fixed crash of Bluetooth settings when device connected
    • 11. Added support ext4, ntfs, exfat for SD cards in recovery mode
    • 12. Added support ext4 for usb storages in recovery mode
    • 13. Added support of multiple storages (partitions) in recovery mode if use System Update application
    • 14. Fixed automatic update error with expanded storage
    • 15. Fixed some crashes of System Update application
    Changelog v.0.2.8+
    • 1. Fixed mouse clicks bug
    • 2. Fixed update from expanded storage if use System Update application
    • 3. Fixed update from usb disks with multiple partitions in recovery mode if use System Update application
    Changelog v.0.3.2
    • 1. Fixed multichannel PCM audio problem. Added automatic detection
    • 2. Fixed SPDIF work for 192 kHz 32 bit audio (AM6, X2)
    • 3. Added high resolution audio support in user applications (sample rates higher 48 kHz)
    • 4. Added PCM audio settings
    • 5. Added SPDIF passthrough support when TV connected to AV
    • 6. Fixed crash when exiting hibernation mode
    • 7. Fixed returning to the same mode when use system AFR function
    • 8. Added restoring last active display mode after HDMI hotplug event if possible
    • 9. Added option for power on via Bluetooth (Device Preferences -> Power)
    • 10. Removed CEC shutdown command when device reboot
    • 11. Added option for power off related devices when going to sleep (Device Preferences -> Display -> HDMI CEC)
    • 12. Changed some translations in TvSettings
    • 13. Made TvSettings window translucent
    • 14. Added top margin for Accessory window in TvSettings
    • 15. Cifs, Nfs clients. Disallow enable client if not filled all fields
    • 16. Changed default wallpaper
    • 17. Added few wallpapers as preinstalled
    • 18. Changed Wireless assistant settings, disabled fireasy by default
    • 19. Added Ugoos remote server
    • 20. Video freeze fixed for mpeg-4 videos.
    Changelog v.0.3.3
    • 1. Fixed work of multichannel high resolution PCM audio
    • 2. Added saving display mode after turning off/on the TV with AV receiver
    • 3. Now default display mode for applications equals resolution in settings
    • 4. Now Lock UI size function worked for all display modes
    • 5. Applications will not be redrawn if enabled Lock UI size function
    • 6. Fixed screen rotation for non FullHD interface
    • 7. Some wallpapers are copied to user folder
    • 8. Added Fake Wi-Fi function
    • 9. Fixed some crashes of application TvSettings
    • 10. Added horizontal recent apps window as option
    • 11. Fixed not worked TV volume control by CEC in some cases
    • 12. Fixed h265 playback crash
    • 13. Fixed interlaced video stream jitter bug
    • 14. Fixed display freezes and becomes slow/lags while selecting PIP mode options in VLC app
    • 15. Fixed freezes when playing 8k video (X3)
    • 16. Ugoos remote changes:
    • - added quick connection menu
    • - added joystick menu
    • - fixed work with third-party keyboards
    • - added multi-touch to the touch screen
    • - added button on-off vibration
    • - added button power off TV box
    • - other changes
    • Dualboot build with CoreELEC
    • 1. Increase CoreELEC partition size to 3GB
    • 2. Replaced CoreELEC night build to stable 9.2.2
    Changelog v.0.3.4:
    • 1. Fixed middle portrait mode of screen rotation
    • 2. Fixed audio passthrough for 2.0 TVs
    • 3. Added new option for HDMI CEC when device turn off or standby
    • 4. Added ability to adjust the volume of AV receivers via HDMI CEC
    • 5. Some gamepads now work
    • 6. Added ability to always use fractional frequencies for system automatic frame rate function
    • 7. Enabled recent apps snapshots for TV ROMs
    • 8. Changed appearance of grant permissions gialog
    • 9. Changed volume bar view
    • 10. Improvements for visibility of more Wi-Fi channels
    • 11. Added dual band Wi-Fi hotspot
    • 12. Added immersive mode option for system bars
    • 13. Some fixes of focus for choice app window
    • 14. Added Ethernet switcher
    • 15. Now fake Wi-Fi option working without reboot
    • 16. Fixed showing IP and MAC addresses when use fake Wi-Fi option
    • 17. Other improves of fake Wi-Fi option
    • 18. Updated ukrainian translations
    • 19. TvSettings. Some descriptions changes
    • 20. Fixed screenrecord utility
    • 21. Changed boot animation (X2,X3)
    • 22. Ugoos remote changes:
    • - bluetooth disconnections fixed
    • - connection status now available on server main page
    • - video streaming bug fixed
    • - some device pairing bugs fixed
    • - Wi-Fi/Ethernet connections stability optimized
    Added the following applications:
    • Opengapps Atv (at the very minimum)
    • App Drawer
    • Power Menu
    • SmartYoutube
    • Explorer X-plore, for remote
    • Alternative Market AptoideTV
    • GoogleChrome v.57. Do not update it, if you want to use copy-paste
    Want to buy me a beer?
    Donation Link Press Here or Here
    Download:
    Install instructions:
    • Use USB Burning tool 2.1.7.3
    • Refer to Ugoos own tutorial how to flash this box!
    The Firmware is made in two versions:
    • 1. img, for flashing via cable or using a specially prepared MicroSD (archive X3_ATV_by_Sasvlad_v....7z, inside the firmware image and file with MD5 checksum).
    • 2. zip, for installation from TWRP-Recovery. Only for those who already have X3 AndroidTV by Sasvlad installed.
    Enjoy it!
    Screenshots:
    Last edited by Sasvlad; 01 September 2020, 16:54. Reason: ?Update: [ROM] Ugoos X3 Android TV by Sasvlad v.0.3.6? (Dualboot and SingleBoot)
    Hi Sasvlad. Can you make the TWRP available to other S905X3 devices?
    Thanks!
      Thanks!
      Theoretically, Yes. But for this I need these other devices.
        Work in any devices s905x3?or only ugoos?
          Can I install magisk in your firmware version?
            Ugoos only.
            Yes
              Are there plans to make this ROM cross compatible with other S905X3 devices, not only Ugoos? I am interested in flashing it on my Bqeel Amlogic S905X3 device.
                NO!!!
                The guys from Ugoos are working hard, but you want to take their work and give it to others, leaving them without money.
                How do you think, which incentives should have Ugoos to make new ROMs if you will stole all their work?
                  Anyone having issue's with the USB OTG USB 2.0 port working in this rom? It was working on first boot. After turning developer options on and off, making a few other changes, etc.. it no longer did. Re-flashing did bring it back to life. Just a little curious what is actually causing it.
                  Any Google Stadia users here? Does not work well at all on this device via chromium. Way to much input lag. This lead me to install the official Stadia app (which requires a Google Pixel to play), and trick the app into thinking it was a Google device to play. Good news is the input lag was gone, Bad news is, the colors are way off, like there is a codec issue? Tinkering with playback settings in X3 settings did not help. Really would like to get this problem resolved. Maybe something to do with the VP9 codec? Not sure.
                  Edit:
                  Just to note to others wanting to try this rom. I was a little confused on the flashing instructions. Just plugging in the OTG cable was not working for me. Here is what worked for me.
                  Box powered off. USB OTG cable plugged into PC and box. Hold reset button in, as you plug the power in. USB burning tool should pick it up, then you can release the reset button. I am sure this info was out there. But I must of found some generic ugoos instructions that did not work for this device.
                  Edit #2: Found some better instructions.
                    Updated: Ugoos X3 Android TV+CoreElec by Sasvlad 0.2.8+ Dualboot
                      ?????? ???? Sasvlad !!!
                      ???????? ?????????? ???????????!! ????? ???????, ? ???? Ugoos X3 cube, ?? ????????????? ???? ?????? ?????????? ? ????????? ? ????????? Android 9 ver. 0.25, ??? ?????????? ??????? ??? ?? ?? Android TV. ????????? ?????? ?? ?????? ????? ??? ? ???????? X2 / AM6 ?????? ?????????? ? ?????????…. ????? ???????? ???? ?????? ??? X3 (ATV by Sasvlad v.0.2.7) ? ???????????? ???? ?????? ???? ?3. ??????????? ??? ??? ??? ????? ???????? ???????, ?? ??? ?? ???? ???? ???????. ?? ????? ???? ??????????, ???????? ??? ?? ???????? ???????? ? ??? «?????? ????»….
                      1. ?????? (?? ?????????) ????? ????????? ????????? ?????? ????? ????? ?????? ????????? (???? ????? ?????? ??? ???? ?????? ?????) ??????? ????? ?? ??????? ???? «???????» ??? ??????? «?????» ??????? ? ?????? ????? ? ??????? ??????????? ? ??????? ?? ????????, ?????? ???? ???????? ?????????. ?? ?????????, ?????????? ??? ?? ????????? ?? ???? ?????? ??? ? ?????? – ???????????…. ??? ??? ????? ???? ?? ?????????
                      2.
                      ??? ????? ???????? ????? ?????? Plex, ????????? ????? ?? ?????????? ???????? ???????, ?? ????????????? ?? X3 ?????????? PLEX, ???????? ?? ?????????, ????? ?????? ?????? ? ????? ???????? ??????? ????? ????? ?????? ??? ?? HDMI ?? ????? ??? ?????? ?? ?????????? ? ?? ???????? ?? ??… ???????? ????????? ?????????? Plex ?? Kodi, ?? Kodi ??????? ??????? ??? ?? ? ??????? ?????? ?? ?? ??????. ??? ?????? ??? Kodi ?? ????? ????? ?? «???? ??????», ?? ????? ???? ????????, ???? ????????? ? ???????? ??????????…. ? ??? ? ? ???? ??????????? ?? CoreElec, ???? ? ????????? ????? ?? ??? ?????????? ??? ?? Kodi ?????? ??? ?????????? ?? ????? ???????? ??? Kodi android ??
                      3. ??? ???? ?????? ??????? ???? ?????????? ?????????, ?? ??? ? ????? ???????? ? ???????: ????????? X3\????????? ???????????????\?????????????? ????????? (????????????????) ?????? ????? ??????????? «????????» (? ???????? ???????? Android 9.0 – 0.2.5) ??? ????? ????…. ? ???? ????????? ??? ?? ?????, ?? ? ?????? ??? ? ????????? ???????, ??? ????? ????? ???? ??????? ?????????????? ??? ????????…. ?? ?????????? ? ??? ??????? ?? ?????????? ? ????? ?? ??? ?????????? ? ????????? ??????? ??????????
                      4. ?? ? ??????? ??????? ??????, ????? ?? ??? ??? ?? ???????? ???????? ATV by Sasvlad v.0.2.7 ?? ???? ????? Ugoos X3 Android TV + CoreElec ?? Sasvlad 0.2.8+ Dualboot ?? ??? ? ???? ?????? ?????? ?????? ???? ???????? ? ??????? ???? ???????? ? ?????????? ?? ? ???????? ????? ?? ??????????? ??????, ?? ?????? ?????? ? ????????? ???? ?????? ????? ?????? ???????? ?????????? ??? ???? ????????, ??? ????????? ????????? ???????? ? ??????? ??????????? ???????????
                      5. ? ???????? ???? ????? Ugoos https://t.me/ugoos_channel, ??? ????????? ?? ?? ????? ????????, ?? ???? ? ????????? ????? ?? ??? ???????? ?? ???? ? ?? ?????? Android ? ????????? ??????? ??? ???????????? ?? Android TV ? CoreElec?? ?? ??????? ??? ? ???? ?????? ??? ????????? ??? ? ??? ????? ?????????… ? ??? ??? ?? ???????? ??? ???????…..
                        Updated: [ROM] Ugoos X3 Android TV by Sasvlad v.0.3.1
                        Updated: X3 Android TV by Sasvlad v.0.3.1 Dualboot
                          Can this box play Youtube HDR?
                            Guys, can you add the IEC61937 protocol which is in the Ugoos X3 firmware to the firmware of another device with the s905x3 processor?
                              Not possible, the whole firmware of the other device has to be rebuilt from source code.
                              Source code for Amlogic/Rockchip devices are 50GB in size per device usually.
