A95X-F3-Amlogic-S905x3 TV Box Review
    A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB 2.4G+5.8G WiFi MIMO USB3.0 Youtube Plex Mobile Control
    Highlights (From webpage)
    Amlogic S905X3
    Amlogic S905X3 applies quad-core Cortex-A55 processors, which is described as an "advanced application processor designed for hybrid OTT/ IP Set-Top Box (STB) and high-end media box applications. The Cortex-A55 cores deliver up to twice the performance compared to Cortex-A53 in memory benchmarks, and a more typical 20 to 30% performance improvement for common tasks at the same frequency.
    Android 9.0 OS
    It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
    8K UHD Resolution
    True 8k picture resolution can be as high as 7680*4320 to achieve 16 times of 1080p picture accuracy.
    Airplay & Miracast
    The TV box supports Airplay and Miracast, shooting your phone's content on the TV and playing games with a bigger screen.
    2.4G+5.8G WiFi with MIMO
    MIMO is an acronym for Multiple Input Multiple Output, It is an antenna technology that is used both in transmission and receiver equipment for wireless radio communication.
    Hi Guys,
    Another Tv box to take a look at today,The A95X F3,An Amlogic S905X3 powered TV box,this is the first Amlogic x3 device iv tested and im liking the results for a 30 quid TV box.The A95X F3 im testing came from the guys at geekbuying so a big thanks to them for the device.This is the 4/32GB version that should be more than enough room for most users,Theres also a 2/16GB and a 4/64GB version both are Running Android 9 out the box.So far so good its doing everything i need with a fast boot up fast UI apps load nice and quick.The pre installed TVMC is also working really good with my favorite kodi build.
    Looks and feel
    Left hand side 1xUSB2 1xUSB3 Port
    Rear
    UnderSide
    It comes with just the one launcher installed.
    An easy to use nice looking one
    The device itself is a slim small square tv box with a front facing clock.On the top of the box is a LED breathing light that does look cool but can also be turned of.The A95X F3 Air has 4 rubber Pads on the bottom so it does not slide around on the desk.The underside has some holes for ventilation.It has 2 full sized USB ports one USB3 & one USB2,Micro SD card slot,HDMI port,Power input,AV port,RJ45 port & a Spdf port not forgetting the hidden recovery button behind the AV hole.The IR remote has good range & works ok (Air mouse is better) or even you can ues HDMI CEC.
    Home Screen
    App Draw
    As advertised this device has OTA updates and yes they mean it as its had one OTA update already
    App's installed
    Air Screen
    App installer
    Browser
    Clock
    Cast play for TV
    Cestus play for TV
    Color LED setting
    File browser
    Gallery
    Google
    K Addons
    Miracast
    Mobdro
    Music
    Media center
    Movie player
    Netflix 480p Only
    Play store
    Amazon Prime video 480p Only
    Netflix 480p
    YouTube (Plays 4k video)
    Root browser
    TV store
    Air Screen
    TVMC (KODI 17.6)
    Some tech stuff
    DRM
    Other info
    Logitech c230 webcam (Works) also installed google voice search and that also works by using the webcam mic.
    Samsung 1TB external HD (Works)
    Tronsmart Mars G01 gamepad (Works)
    32GB micro SD card (Works)
    HDMI CEC (Works very well)
    Rooted out the box(Can be turned off in settings)
    Controll the TV box with your phone
    Internal photos
    Specification
    General
    Model: A95X F3
    Type: TV Box
    Hardware
    System: Android 9.0
    CPU: Amlogic S905X3
    Core: Cortex A55,Quad Core
    RAM Type: DDR3
    Max. Extended Capacity: 64G
    Communication
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: 4.0
    RJ45 Port Speed: 100Mbps
    Media
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV
    Audio format: AAC,FLAC,MP3,OGG,RM,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    Interface
    AV, DC Power Port, HDMI, LAN, TF card, USB2.0, USB3.0,Optical
    Other Features
    Antenna: Yes inbuilt
    Camera: Without
    Language: Multi-language
    HDMI Version: 2.1
    Other Functions: DLNA,ISO Files,Miracast
    Power Consumption.: 6W
    Power
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA Battery ( not included )
    Dimensions & Weight
    Product weight: 0.1250 kg
    Package weight: 0.3810 kg
    Product size (L x W x H): 7.70 x 7.70 x 1.70 cm / 3.03 x 3.03 x 0.67 inches
    Package size (L x W x H): 15.70 x 11.60 x 5.90 cm / 6.18 x 4.57 x 2.32 inches
    Package Contents
    1 x TV Box
    1 x Power Adapter
    1 x HDMI Cable
    1 x Remote Control
    1 x User Manual
    Unboxing video
    To buy this TV Box please get it from our friends at geekbuying
