FW for MXQ PRO+
    FW for MXQ PRO+
    Hello,
    I've tried a number of different firmwares on here and on atvxperience, however I haven't found any firmware that works with this box correctly:
    Specifically, its a s905x with wifi hs2734a
    Can anyone point to a custom rom based on android tv that works with this device?
    Mac
    Hello,
    you can try the firmware of the probox2 air.
    same spec.
    Go to probox2.com download.
    Neomode
      Thank you.
      I downloaded the firmware and it is a ZIP file. (Note that I an new to this so I don't understand the difference between a ZIP file update and an "img" file that you would update via a USB Burning tool. I've only ever managed to load "img" files via the USB burning tool).
      In any event, I tried installing the probox2 air ZIP file (PROBOX2-Air-20170527.zip) from Android Recovery and I got the following error message:
      "This package is for "p212" devices; this is a ""."
      Any ideas?
        Originally posted by mac_will View Post
        Thank you.
        Any ideas?
        Hi ,
        sounds wrong , are you sure it fits , already tried it with PC ??? , this cheap MXQ Boxes made with so many different CPUs & Specs that you cant even count them , hope you find what you need ,
        good luck / gefattern
          I am sure it fits yes.
          Same Hardware, or why should I told him use it?
          Let me get the img file to Burn from PC.
          Neomode
            Thanks very much. I would appreciate the img file for that firmware.
            Mac
              Mac
                Neomode
                neomode is the img for the probox2 the same as the link above provided by sagert ?
                  No but use that from sagert.
                  Seems to be perfect .
                  NeomodeĀ
