Is there anything better
See:
However I thought that the issue was solved.. with the latest OTA update..
Check if there are updates for your mi-box
Check manual of TV some support Color space changes in settings
Note.. buying a new tvbox..might not solve your green stripe issue.. aka new box might give you the same results
About the 40 bucks new device... it depends on your use case
If its to watch Netflix then the rk3318 might be limited to 560p
see:
or look on YouTube for reviews about the h96 max
if its for watching streams/vids then Fire Stick 4k would be my choose
Cheers
There are currently 1838 users online. 1 members and 1837 guests.
