Any updates for this box?
Could you post more pic or info..
The black bar with 'home' is called 'systembar
it can be removed many ways..
-try this
go to the 'home-screen' and click 'home' button on remote -many times' do you see a arrow pointing down?
If yes.. click on it with the mouse.. when it appears...the bar should be gone ( now you can run xbmc fullscreen )
Option 2
installing a app called 'fullscreen' or ' hidebar'.. this requires 'root'
-so, first install a 'root checker' app and check if your unit has 'root' enabled..
Q :
Does the device have a 'otg' port ? or post pic of the back of the unit
Does it have 'root' ?
If your unit has 'screencapture' support post pic's of the 'settings' and 'device/kernel info' page
Cheers..
Do you have a stock ROM image?
Originally posted by joe6915 View PostHi
How would i get the stock rom?
Another way is to dump your ROM so we can make the dump flashable stock ROM.
The device is called 'acemax iptv418'
The have a site 'acemax.net.cn' and the twitter.. and on alibaba you can chat
Perhaps you can ask them for fw ?
Wierd.. perhaps try a different 'root checker' app (encase the first gave a fails possitive)
--looking at specs.. it does have a 'otg' port (for fw backup or upgrade or rooting)
Cheers
If your speaking to Chinese they do not know what the word ROM means. They call it a Brush.
Yes a Brush. Tell them you need factory brush file.
Joe6915,
There is no any doubt at me. This is CX-921 box. I was going to order it, but refused. There are a lot of place with firmware, but I unfortunately deleted mine.
Try to use this link http://www.freaktab.com/showthread.p...M-by-Lewy20041CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
I have tried that rom and box is stuck on boot screen :-(
Hi Joe6915,
Sorry, but I don't have this device and can't check whether firmare which link I suggested to you working or not. I only tried to help you with searching.
I'm 100% sure that your device is CX-921. Try to type this name in aliexpress and you'll be able to see huge number of your device's brothers and compare their appearances and specifications with your box.
Only one important thing can be different. It's a RAM size. It can be 1 or 2 GB for this device. I don't know, probably ROM you have flashed, was created for 2GB RAM modification but you have 1GB.
You can find the stock firmware for CX-921 on geekbuying download page http://blog.geekbuying.com/index.php/firmware-download/ .
Good luck!CS918II/16GB(HTC-031-V1.0 board)
There are currently 2083 users online. 3 members and 2080 guests.
