CENAVA BM108 10.1 inch 4G Phablet uses high performance MT6762 Octa-core CPU, which has lower power consumption and longer battery life. The latest Android 9.0 operating system, chip with AI intelligence is able to optimize and accelerate machine's performance. 6000mAh large capacity battery allow the local video playback up to 8 hours.
Main Features:
●MTK MT6762 8 Core 2.0GHz Processor & IMG PowerVR GE8320 GPU
It is 8 Core structure, achieving high performance and low power consumption. The GPU is better and faster in playing games and watching videos than the previous generation.
●4G Network and Phone Call
Support TDD+FDD 4G network and dual SIM card slot. The network is uninterrupted during a call.
GSM: 850/900/1800/1900MHz
WCDMA: 850/900/1900MHz/2100M
TD-SCDMA: B34/B39
CDMA: CDMA800 ,1x EV-DO
TDD LTE: B38/B39 /B40 /B41
FDD lTE: B1(2100)/B2(1900)/B3(1800)/B5(850)/B7(2600)/B8(900)/B28(700)
EU version: FDD LTE: B1(2100)/B3(1800)/B7(2600)/B20(800)
US version: FDD LTE: B2(1900)/B4(1700)/B7(2600)/B12&B17(700)
Support domestic CA
●10.1 inch HD IPS Screen with 1280 x 800 Resolution
Features 10.1 inch full HD IPS screen, optimizing the picture color and display with AI intelligent image algorithm.
●Big Speaker and Large Volume
Big size speaker with large volume enhances your experience, whether you are working or getting entertained by any media.
●Android 9.0 and AI Speed-up
Makes you work and entertain with more excellent interface, compatibility and running effect.
●4GB RAM 64GB ROM
4G large RAM to keep system running properly. TF card slot allows to extend the storage.
●Long Time Battery Life
● Dual Camera
Rear 13.0 MP and front 5.0MP, anywhere with 4G network.
●AC Dual Band WiFi and BT 5.0
More bands for you to choose.2.4GHz band is better at penetrating obstacles while 5GHz band will offer faster connection speeds. Bluetooth 5.0 is faster than the BT4.0 with further transfer distance.
