Looking ROM Amlogic S905X Ram 2GB , ROM 8GB
    am looking for rom for the following specifications Amlogic S905X processor, - quad core ARM Cortex-A53 @ up to 1.5 GHz with penta-core Mali-450MP GPU @ 750 MHz - 2GB RAM - 8GB ROM which supports double joysticks. help me please
    Hello,
    No Problem please try this Firmware.
    It is Android 7.1 and the most stable Firmware for this Boxes.
    Regards
    Neomode
      ok i will try first, thank you very much, oh y how to install it
        Installation will be done with your PC and USB Burning Tool.
        Also you need a proper USB Cable.
        Neomode
          here are 3 files that can please complete the detailed tutorial, I'm still confused for these 3 files, because I'm used to flas only 1 file img
              Seems it need more Power for flashing.
              connecting power before start Burning.
              Neomode
                already using power but still error
                  already using power but still error, here are 3 files in the folder, how to flash it
                    Originally posted by neomode View Post
                    Hello,
                    Regards
                    Neomode
                    perfect
                    perfect
                    perfect
                    I tried and succeeded. wish you good health
