Beelink BT4 Intel Atom X5 z8500 4/64GB Dual WiFi Gig lan support VGA and HDMI output
    Beelink BT4 Desktop Mini PC
    Intel Atom X5-Z8500, Intel HD Graphics 600, 4GB RAM + 64GB EMMC, 2.4GHz + 5.8GHz WiFi, 1000Mbps, 4 x USB3.0, BT4.0, Support 4K
    Description: as found
    Beelink BT4 Mini PC comes with chipset Intel Atom X5-Z8500 CPU, and it provides you a smooth experience to watch the videos or play games, with USB 3.0 port, make the transmission faster than before. Its faster speed gives you higher working efficiency. On the other hand, BT4 is also the best choice for your family entertainment, you can have your family members play games or watch TV shows together.
    Main Features:
    ?Powerful processor
    Equipped with Intel Atom X5-Z8500 CPU which is advanced in image processing and computing. Its high machine configuration gives you ultra-fast running speed and smooth image processing performance. With the HDMI 2.0 data output, it makes sure you can enjoy 4K x 2K, even 3D HD movies.
    ?Advanced operation system
    Support for fast and powerful Win 10 operation system. Perfect for working, watching TV and playing games. Rapid, stable configuration coupled with the highly Win 10. Support dual-screen, reduce the waiting time, improve your work efficiency. Say goodbye to the system freezing and buffering.
    ?Convenient to use
    Support multiple connections such as Ethernet 1000Mbps, standard RJ45, Bluetooth 4.0 and 2.4 / 5.8GHz WiFi. It is very easy to install, as soon as you plug in the power supply and connect the box to your WiFi or else way, you can watch whatever you like. Users can surf the Internet with browsers and have a communication with the world through kinds of APPs, like YouTube, SKYPE video call, MSN, facebook, also the hot films and TV shows can be searched at any time.
    ?Practical multi-media player
    A practical home streaming media player, feel free to enjoy all your favorite movies, sports shows, and entertainment programs. And you can also save the games, movies and TV shows you like, support the SD card extended to 128GB ( not included ).
    Performance Parameter:
    ? Work environment: -10 - 45 Deg.C, 30 - 90 percent humidity
    ? Storage environment: -20 - 60 Deg.C, 10 - 90 percent humidity
    ? Adapter 12V - 1.5A 18W
    ? Certification Input: 100 - 240V AC, 50 / 60Hz, Output: 12V 1.5A
    ? Built-in CR2032 210mAh battery
    Gearbest
    Keeping with the Intel theme of late
    Today it is the turn of the Beelink BT4
    Beelink BT4 Desktop Mini PC - Black 4GB RAM + 64GB EMMC
    Intel Atom x5 - Z8500 Intel HD Graphics 600 / 4GB RAM + 64GB EMMC / 2.4GHz + 5.8GHz WiFi / 1000Mbps / 2 x USB3.0 / BT4.0 / Support 4K 30fps
    Now you maybe thinking that is the same as the Beelink T4 well it is and it isn't sorta
    We have HDMI and VGA and as you will see smaller heatsink and a fan.
    The rest will be pretty much the same as the T4
    Again aimed at the small Home user or Office
    Like all these Intel MINI PC should be able to handle just about all your daily needs with a minimum of fuss and bother
    Hard core games and CPU intensive programs etc common sense should advise this may not be suited.
    Office application Social games Netflix 1080p, Kodi etc ideal small unit,
    Most of the Features as mentioned the same as the T4
    You can read all about it
    https://forum.freaktab.com/forum/tv-...879#post788879
    Let's have a look see at what we have
    The Box:
    Contents of the Box:
    Ports a Plenty
    Remove the base
    Remove Heat sink and fan:
    Out with the PCB, not a lot here
    Gearbest
      This Beelink BT4 Mini PC much the same as the T4 I was curious to Ram Performance and a bit of a stress can a large block of All compete against less alloy and a small fan
      Well missus out only by a few degrees only so not to bad and the fan is small can hardly hear it al all
      CrystalDiskMark Test: Very little difference seen as compared to the T4
      Stress test: Not to bad only a few degrees more than the T4
      The Cool down bit quicker
      CPU Type:
        Looking for the drivers for the Beelink BT4 miniPC. Did a clean install of the Windows 10 OS, so lost the drivers. No audio at all, knowing the audio module would help. I think it is a Realtek, but not sure. Beelink support is out for their holiday until after January 30, 2020.
        thanks
          Hi there
          Weird should have picked it up with ease, have you done all the updates to the latest and greatest Versions
          Is it in device manager as an Unknown device ?
            Originally posted by trebor View Post
            Hi there
            It picked up everything except audio. I downloaded and installed some audio drivers, but they did work. I was trying to install LibreELEC onto this device, but no go.
Name:	no audio.jpg
              Go to the Intel site I recall and get the latest Intel drivers it may scan your PC
              https://www.intel.com.au/content/www/au/en/support/detect.html
                While you do that i will make a back of drivers and post just in case if i remember how its all done..
                  Ran the tool, but did not correct the problem.
                  You don't have to grab your drivers, I know your plate is full already.
                  I can wait for Beelink, they will give me the drivers. I was surprised that the Windows Home activation popped back up. I thought for sure I would have lost that activation code.
                    Download this
                    Extract the zip
                    Under Media Dir
                    Intel sst DIR
                    Right click on oem26.inf and click install
                    Back one Dir
                    Realtek I2S DIR
                    Right click on oem51.inf and install
                    All being well should work:
                    or you can do the have disk and browse to the Dir
                    Only thing what you have installed already may clash and cause grief
                      Download this
                      Extract the zip
                      Under Media Dir
                      Intel sst DIR
                      Back one Dir
                      Realtek I2S DIR
                      You still amaze me... Don't know how you got those drivers so fast.
                      Anyway, the oem26.inf would not install says something about hash missing so file could be corrupt. Will dig into it tomorrow. After midnight here, now.
                      Thanks for your help.
                      • trebor
                        trebor commented
                        Editing a comment
                        No worries
Name:	Annotation 2020-01-22 003345.jpg
Name:	Annotation 2020-01-22 003550.jpg
Name:	Annotation 2020-01-22 003658.jpg
                        Hmm try one of these
                          removed
                            After much persistence, finally found the correct audio driver. Here is the link I got the driver. It was the 3rd download that was correct.
                            https://www.catalog.update.microsoft...e%20(WDM)%2010
                            That link worked!!!! Back in business. Thanks again, masked man.
