ONE MIX 3 PRO WORLD’S FIRST MINI-LAPTOP WITH A 10TH-GEN INTEL PROCESSOR
    2 In 1 Tablet
    OneMix 3 Pro can be both a laptop and a tablet due to its 360 ° Hinge.
    Laptop mode is used for office entertainment, and tablet mode is used for reading and creation, which can be easily used in airplanes, cars, high-speed trains and offices to improve work efficiency.
    Fingerprint Recognition
    It allows you to get access to your device quickly, convenient, secure and fast.
    Backlit Keyboard
    Integrated infrared pointing mouse for easy and accurate typing at night.
    CPU: Intel Core i5-10210Y, Quad Core Octa Thread, up to 4.0GHz
    10th-gen Intel processor gives One Mix 3 Pro a powerful business office performance and delivers plenty of power for multitasking, gaming, and movies.
    GPU: Intel UHD Graphics
    On-processor graphics with shared video memory provide high image quality with basic photo editing and casual gaming.
    16GB LPDDR3 + 512GB PCI-E SSD
    16GB LPDDR3 offers a fast read and write speed which allows games and programs to run smoothly. 512GB is sufficient for the average user's data storage.
    8.4-inch Touchscreen With High 2560*1600 Resolution
    High-resolution displays for tablets. It is perfect for everyday use, but also suitable for specialist workloads.
    8600mAh Large Battery
    Use this laptop all day and night on one charge.
    Windows 10
    Equipped with the latest genuine Windows 10 operating system with up to date software updates.
    Dual Band 2.4GHz / 5.0GHz WiFi
    802.11a/b/g/n/ac wireless Internet, allows you to connect to the Web while within range of an available wireless network.
    Specification
    General Brand: One Netbook
    Model: One Mix 3 Pro Set(English Version Keyboard)
    OS: Windows 10 home
    Fingerprint recognition: Yes
    Storage RAM: 16GB LPDDR3 Dual-channel
    SSD: 512GB PCI-E SSD Onboard
    External Memory: Micro SD card up to 128GB (not included)
    Display Screen Size: 8.4-inch Multi-Touch, Support Touch Screen
    Display Ratio: 16:10
    Screen Resolution: 2560*1600 IPS
    Network WIFI: Wireless 802.11a/ac/b/g/n,2.4/5GHz Dual-band
    Bluetooth: 4.0
    I/O Interface I/O Specifications: 1x Type-C(USB3.0 Gen2),1x USB 3.0 Gen1
    Video Interface: Micro HDMI D Type
    Audio Interface: 3.5mm Headset jack
    Other Interface: 1x Micro SD Port
    Power Battery Type: None-removable Li-Po battery
    Battery Capacity:8600mAh 3.7V
    Battery Life: About 12 hours, it should depend on the actual working conditions
    Charger Specifications: PD Fast Charge
    Multimedia Input: 100-240V-50/60Hz 0.7A Max
    Output: 5V3A,9V3A,12V2.5A,15V2A,20V1.5A
    Audio Format: Mp3/Mp4/Wma/Ogg/Amr/Aac/Flac/Ape/Wav/MidI/Ra
    Video Format: Mp4/Ape/Wmv/Rm/Rmvb/Asf/Avi/Mov
    Picture Format: Jpg/Png/Gif/Bmp/Jpeg/Webp/Wbmp
    Stylus Pen Instructions: Touch type handwriting pen
    Sensitivity: 4096
    Geekbuying
