Looking for more clear upgrading/updating my box Amlogic S905x
    Hi there,
    I'm new at forum. I reaching it looking for information about tvbox and upgrade/update procedure. Why? Issues with mine. It's a huge information here and other sites about it, but I have some doubts and request your help some help to understand them.
    In most place talk about be sure of your brand/model, there are a huge of them in the market and unfortunately a lot of them are really bad (mine is one, I didn't know about this device when I bought it, often get stuck, many applications warn that they are not optimized for it, and has become a bore and the seller, close the local shop, so the solution go there to get refund is not an option.
    The next future is to buy a new one, but can to try something before to do it. If this don't right, I assume that I will get a brick, perhaps a better decorative item. I don't pretend want to upgrade to latest version of Android, but I want to have a functional box if possible, perhaps last version of Android 6.x or 7 at best.
    When you say pay attention on your tvbox model to apply firmware, it means it has the same model of proccesor (Amlogic S905x) for my box at this moment. I understand that I should not update a S905W, S905X2, Rockchip... or whatever one, but perhaps other brand with same processor could be well on it, or must I take into other parameters as wifi, bluetooth, hdmi, usb features as mine? I'm something confused with this issue, because i can read a lot of people with brick device. Why a tvbox could brick if you have the correct firmware S905x processor version? ¿..? Some guys share rooms, projects, stockroms, and others tools and really appear easy to apply, but I continue reading about others bricking their tvbox? What is the fault?
    Here I leave a screenshot of features on external box, other picture with the board inside box, other with info of the box.
    Click image for larger version  Name:	muvip_mv84k_amlogic_ZH905x.png Views:	0 Size:	195.3 KB ID:	792956
    Click image for larger version  Name:	muvip_mv84k_amlogic_ZH905x_board.jpg Views:	0 Size:	95.9 KB ID:	792957
    At this moment the Android TV version is 6.0.1 an magically is rooted. I didn't root it never. Sincerely the use of the tv box is simple (Netflix, Youtube... I don't use more than 4 or 5 streaming apps on it. I don't need the root reature here. If i reach to update to a new firmware and I lose the root access, I'm not gonna lost the sleep.
    Regards
