Android 9 for Amlogic S912
    Recently S912 v boxes are released with Android 9 OS, something that previously was said to never happen, because Amlogic wouldn't release a Android 9 SDK for the S912.
    So what has happened, is this a full fledged version with a SDK released by Amlogic, or a modified version created by the Chinese?
    Are there any reviews yet about performance and/or bugs?
    I'm particularly interested to know how it performs on the Mecool M8S Max, and if it is possible to flash a 7.1 ROM on case performance is not as expected.
    Where did you see Andriod 9 on a S912 ??? I have looked and still haven't found any production models available.
      I received a batch of Mecool M8S Max yesterday and on the box it says OS Android 9.0
      I have to admit that I haven't had time to connect, but will do today.
      Since your comment indicates that there is little chance of any hands on reviews yet, my main question is, can I flash a Android 7,1 ROM to the device if Android 9 disappoints?
        I suspect that the device label is just incorrect, and you most likely have all Android 7.1.2 firmwares in those new devices. But, yes if the hardware is exactly the same as the Mecool M8S Max that came with Nougat originally you should have no problem installing Nougat if it did get upgraded to PIE.
          I quickly connected one, and no it isn't mislabled
            LOL
            You must have fake Mecool devices, the seller/vendor or manufacture did a Build.Prop cheat and renamed the device to say Android 9.
            If you actually had Android 9 made from a legitimate Amlogic source coded SDK your device would have a Linux
            4.9.xxx kernel and not a 3.14.29 kernel build.
            Also note the build number which has NHG47L which is Google code for a Nougat Android 7.1.x build.
            Load a root file manager like ES File Explorer and check the version number of the system apks and see if the framework is indeed 7.0 or 7.1.1 or 7.1.2.
              LOL
              My boxes are purchased directly from Videostrong, who I doubt makes copy of their own product.
              Please explain more detailed how I check the framework of system apks, as I have root explorer installed
                You might be right, in the build properties it says SDK 25.
                If there is another way to check the framework let me know.
                So why would a company like Videostrong label their OS as v9 when it's actually V7.1?
                  Well that answers it, it is Nougat.
                  The stock system apps that don't get play store updates will display a version number after you click on them in file managers like ESfile or TotalCommander, and so if the apk was compiled for a SDK of Nougat the version number will be 7.0 or 7.1.1 or 7.1.2
                  If they are directly from Videostrong, then the software engineer is not clearing the data/cache in his/her build environment and either data got migrated over from previous builds made on same computer or they are complete idiots.
                    Please name such a stock system apk and in which location to find it
                      Using ES-File-Explorer,
                      when you first open app click the APP tab,
                      change the sorting from "User Apps" to "System Apps" then locate Android System and click on it,
                      the package name is just android - this is your framework,
                      the version number for original first release Nougat will be 7.0(24) - the (24) is the SDK/API designation of the software
                      hope that helps,
                      P.S.
                      when I was talking about system apks that dont update, i was referencing apks like: Contacts Storage, Calendar Storage, Google Backup, Media Storage, etc.
                        hope that helps,
                        P.S.
                        I can't open them but these are the properties. Hope these are the files you had in mind.
ID:	793007Click image for larger version
ID:	793008Click image for larger version
ID:	793009Click image for larger version
ID:	793010Click image for larger version
ID:	793011Click image for larger version
                          That is fake boxes or someone did crap in factory or like rick said some engineer did crap... That is android 7.1..., they just grab the tvsettings from android9 and stick it in android 7.1 not that hard to do actually!
                          Actually i just did a 9 build for s912 and im facing lots of issues, must are fixed already except the bigger one that is the framebuffer issue, extremely hard to fix if ever fixable!
                            Like I said, buy them from videostrong directly, and as far as I know they are the original manufacturer.
                            So is there actually a S912 box on the market that comes with Android 9 from factory?
                              Nop theirs not!
