LibreELEC and Armbian for Allwinner TV box
Originally posted by balbes150 View Post
According to the log, you are running the official version of LE. This topic discusses another (unofficial) LE build. Therefore, if you have questions about the official versions of LE, you need to contact the official forum in the appropriate topic.
Thanks for your quick reply, sorry i uploaded the log for the official "Libreelec" as i follow with them too, but with the unofficial build here i can see some success as output appeared on TV for one second then black screen, on official "Libreelec" always black screen, kindly find the log for the unofficial build in attachments.Attached Files
Originally posted by genidy.m View Post
Dear balbes150,
mem=2048M video=HDMI-A-1:e
The string must be like this
APPEND=root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mem=2048M video=HDMI-A-1:e
Try adding APPEND to the string
I tried with "mem=2048M video=HDMI-A-1:e", same thing black screen, but after reversed console to start with "console=tty1 console=ttyS0,115200"? instead of ? "console=ttyS0,115200 console=tty1" "HDMI" output working, so removed "mem=2048M video=HDMI-A-1:e" and keep console reversed also working, so it appear if i reversed console entry "HDMI" working, also tried to reverse in official "Libreelec" and now working too, also if i removing "console=ttyS0,115200" and keeping "console=tty1" screen goes black again, so two console entries must exist and reversed, moreover i facing a new issue that it stuck at "mmc1: new DDR MMC card at address 0001", kodi not started., same thing with official "Libreelec" too
Dear balbes150,
Try the combined launch option (burn the image to two media at once SD card and USB flash drive and connect them together to the TV box).
not working same thing but you give me a hint that it maybe stuck because it didn't recognize the "boot and disk" label entry also same thing in official "libreelec uses UUID instead of label", so i replaced those entry to use device logic name like this "APPEND boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 console=tty1 console=ttyS0,115200" and now worked very well, i don't know why it can't handle label or uuid, but for now it working well, i will play with it to discover it, finally i really thank you for all your support and thanks all "Libreelec" guys for that OS, it working really very fast, beautiful interface, i like it very much than ugly android os.
Originally posted by Kernel26 View PostI have see that pendoo x6 pro was a clone od Tanix T6. Can i install a dual boot system on it.
Tks!
Updated specialized images Armbian for Allwinner H6 to version 20.07. They now use the 5.7.7 kernel and u-boot-2020.07. The new u-boot-2020.07 (catalog 20200709 on the site) for Allwinner H6 is also available as an additional file for use with universal images .
Update Libreelec ver 20200710 kernel 5.7.8
The new version of images 20200816 kernel 5.7.15.
Please note that the algorithm for initial configuration of the system for startup has changed. Instead of a file "uEnv.txt", the file "/extlinux/extlinux.conf " is now used.
For the Allwinner platform, you no longer need to rename the scripts "boot.scr".
All "boot.scr" scripts have been canceled and are not used.
There are currently 2196 users online. 0 members and 2196 guests.
