(ROM) Minixfreak_OS V3
    Changelog V4
    Dec 28 2019
    -Based On Beelink GT1 MINI 004P0 005P0
    -True Android TV Experience
    -Optimized SystemUI
    -Tweaked Wifi Drivers
    -Voice Search Is fixed And Optimized
    -AndroidTV Remote Fixed
    -Updated Gapps
    -SuperSU
    -AutoFrameRate App (Thanks 4PDA)
    -Stock Recovery
    -App Drawer
    -Fixed Some Permissions
    -Add Bluetooth Mobile To Settings
    -SmartYoutube (No Ads)
    -IPTV Reboot issue Fixed
    -Updated Codecs
    -New Framework ATV
    -Backported Simple Fixes From Other Platforms
    -Fixed Cec Issues
    -Updated Busybox
    -Added Extra Remote Layouts
    -Added Gamepad Support
    -GPU Tweaks
    -CPU Tweaks
    Pre-Installed Apps
    -Kodi 18.5
    -Dark Media IPTV (AMAZING IPTV) SIgn up, you wont regret it
    -STB Emulator Pro (For ppl with Other Iptv Services) Your Welcome
    -Google Chrome
    -Xplore File Explorer Pro
    IPTV
    Website is https://hustleman.tv/
    When Ordering your service make sure you add recommended By Minixfreak In note section
    3 Service to choose from single and multi connections also
    BEST SERVICES AROUND
    I TESTED ALL 3 SERVICES ALL AMAZING, Pick the right one for you along with your budget
    SAVE 5% OFF YOUR ORDERS, CODE IS " MINIXFREAK "
    Bugs
    -You Tell Me
    Tips
    -Allowing permission to an app will shut down the app but just open it again and you're good to go
    -Get rid of supersu notifications turn off under the supersu settings
    -First boot can be sluggished due to all the apps and google framework updating
    Downloads
    Builds Are Uploading
    Android tv remonte problème
      Noted... Can someone send me logs ? So i can figure out the issue ....
        How do I do ? the problem is the same as poison atv
          Logcat google it
            Will be working ok a new build v3.1 soon to fix some issuea with voice and androidtv remote
              Good thank you
                thanks for the huge job you are doing, i look forward to version 3.1
                  Originally posted by minixfreak View Post
                  Changelog V3
                  Dec 21 2019
                  -Based On Beelink GT1 MINI 002P0 & 004P0
                  -Optimized SystemUI
                  -Updated Gapps
                  -SuperSU
                  -Stock Recovery
                  -App Drawer
                  -Updated Codecs
                  -Framework Modded for my needs and ATV features
                  -Fixed Cec Issues
                  -Updated Busybox
                  -Eliminated All Keyboard Except Leanback ( My Modded One)
                  -GPU Tweaks
                  -CPU Tweaks
                  Pre-Installed Apps
                  -Kodi 18.5
                  -Google Chrome
                  Bugs
                  -You Tell Me
                  Tips
                  Downloads
                  https://mega.nz/#F!R4JHHKDY!6yvzxiHOVQE2XbCcgcW9zA
                  Any help would be much appreciated, are any firmware’s 64 bit ?
                    No sdk was not released in 64bit ...
                      Thanks so much for the response, so that goes for any version Pie or Oreo ? And non ATV ?
                        Correct...it was reported elsewhere an AML 64 bit firmware will be available on android 10...
                          Hi, is this firmware compatible with T95Q s905x2 4GB ram?
                            no but if i had the device i would make firmware for it ..... i could possibly do it blindly but we shall see
                              Thanks for the info, that sounds like good news then as far as Android 10 goes, shame about the wait.
