BEST ANDROID TV OS FIRMWARE 7.1.2 (ROOTED) FOR ALL TV BOX S905W
    Hi friends
    while searching on youtube I found this best firmware, and miraculously it works on my m8s plus with wifi etc
    All ok
    You can test it on (W95 / TX3MINI / X96MINI / m8s pro and somes ...)
    Android tv version
    Link https://drive.google.com/file/d/1EFN...e3fTMo9tH/view
    The video here
    Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
    Or
    Normal android version
    Link https://drive.google.com/file/d/1BhJ...5MjYopssR/view
    The video here
    For m8s pro w v2.2 and v2.3
    my rom:
    M8S_s905W_v2.2_v2.3_Android_Tv
    https://mega.nz/file/Flw2FCjY#Kxs-Dv...TsqTML2GTdc89A
    M8S_s905W_v2.2_v2.3_Normal_Android
    https://mega.nz/file/Jl4A3abZ#q4Sgyl...jtNQ81p4qrI4Vo
    Good luck
    Did you test netflix app? Working? HD?
      Not working, just sd
        Originally posted by algdu831 View Post
        Hi friends
        All ok
        Android tv version
        The video here
        Or
        The video here
        Good luck
        how to flash this in tx3 mini?
          Test with simple update or USB_Burning_Tool with cable
            Installed on TX3 mini, working very good for now but how to fix display to display clock, stuck on word "boot"?
              copy this files from stock FW....
              #root
              system/app/LedStatus/LedStatus.apk
              system/bin/FD628Service
              system/bin/preinstall.sh
              system/framework/services.jar
              system/lib/aml_fd628.ko
                Hi ,
                really for all S905W Boxes , for sure not , with the right supported Wifichips / right RAM / ROM size,
                what Wifichip does your Box use , add this , if possible , so not so many Boxes get bricked ,
                greetings / gefattern
                  Is wifi working on the tx3 mini a?
                    You will have to test yourself to find out.
                    Maybe take the cover off your box and try to source your wifi and ethernet tranceiver plus CPU and Nand etc...
                    Take some pictures also.
                    Always make a backup of your current ROM
                    Then Factory Reset* This is part of my method of madness and optional
                      Version V2.5 MEE (cOOLio - good work) now also stops on the screen with logo, even though it worked before.
                      Please, what can I do to make my box work again?
                        Rom just installed, works pretty well on the tx3 mini a. Also wifi ?
                        Original Netflix from Google store doenst work. Only one version from the other antoide store.
                        Disney app from that store can be start. But then crashes. Hopefully a working version is coming soon.
                        Also a cannot stream from my mobile to the tx3. Cannot see the device. But also no Bluetooth option in the settings menu
