Audio Dissappear Frequently
I have a H96pro plus 3/32 running SCV4 blue pcb rom. It was working fine from two years, in last few days, audio get disappeared frequently on HDMI. I have tried to check with different HDMI cables but problem is still persistent. Whenever it happens, i have to reinsert HDMI cable or restart tv or rotate input source from HDMI to any other like usb or antenna, and audio come back. But after a few minutes it gone again and had to repeat that process to restore it. So anybody please suggest me, what to do now to fix that problem.Tags: None
If you are "Hot Plugging" your HDMI...you are on the path to killing your China Box or T.V.
Try to make a TWRP back-up of your SCV4....to re-install later if things are not to your liking.
Any of the suggestions below are to help confirm that it it not a software issue.- Uninstall all non-standard programs (All? It takes only one little buggy app to bork a system.)
- Do a factory reset (Wiping your system to kill any background program that is causing the problem.)
- Re-install SCV4 (More thorough affect as above.)
- Upgrade to SCV7a (Might leave offending problem still in background if you do not start with a freshly wiped system.)
There are currently 1772 users online. 1 members and 1771 guests.
