EACHLINK X3 MINI Android 9.0 Smart 4K TV Box - Black 4GB DDR4 +64GB EMMC
    Thanks to Gearbest today we can have a close look at the
    EACHLINK X3 MINI Android 9.0 Smart 4K TV Box 4GB DDR4 +64GB EMMC
    EACHLINK X3 MINI Descriptions as found
    Enjoy a more beautiful image video
    EACHLINK X3 MINI Android 9.0 smart 4K TV box comes with Amlogic S905X3 Quad-core CPU and ARM G31 MP2 GPU, making it run more smoothly. Support 8K UHD resolution, you can see more detailed and more beautiful images.
    Main Features:
    ?Amlogic S905X3 Quad-core CPU + ARM G31 MP2 GPU
    Comes with the high-performance CPU + GPU, making the X3 MINI TV box run fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games, which improve the running speed and enhances the image processing capability.
    ?Android 9.0 OS
    Adapted Android 9.0 operation system for strong compatibility, it is compatible with more software, games, and applications to improve user experience.
    ?HEVC H.264 VP9 AVS2-P2
    Various video decoding can save more bandwidth resources, let you watch the 8K movie smoothly.
    ?8K UHD Resolution
    Support multi-video decoder up to 8K 24fps, 4K x 2K @ 60fps + 1 x 1080P @ 60fps, which provides much more detailed and better-looking image.
    ?4GB RAM + 32GB / 64GB ROM
    4GB RAM + 32GB / 64GB ROM storage memory allows you to display HD video smoothly and download massive resources from the Internet, it is large enough to store large numbers of movies and Applications and browse the web, etc.
    ?USB 3.0
    The transfer speed is theoretically 10 times faster than USB2.0. You can quickly transfer movies, images and other resources from USB drives or mobile devices to the TV box for playing.
    There is a lot of these 905x3 popping up of late and more to come no doubt.
    Most by now have the firmware running pretty good/OK also options with CoreELEC and others I recall.
    Let's not dilly dally and get on with the show...
    The Box:
    What's in the Box
    Ports all around
    Side Ports:
    Rear ports:
    Front on view:
    Underside:
    Case and PCB out:
    Top View:
    Not a lot under here:
    Again thanks to Gearbest today we can have a close look at the
    To Continue on:
    The setup of Google Play Store ok:
    Wifi and ethernet speeds Good
    Google would not install apps just pending:
    Onto APK Pure and all good.
    UI looks kind Groovy and clean/not busy, No Root, No task/notification bar
    It's a fairly locked down Rom not much to fiddle with very basic at this stage, but performance for a 905x3 is on par with others
    Good custom rom will fix his sucker
    On with the Show:
    UI, Installed Apps and Info:
    DRM Info L3:
    Antutu:
    Wifi 2.4 and EtherNet:
    CPU-Z:
    Aida 64:
    Sd Card Test:
    Gearbest
      "Good custom rom will fix his sucker"
      Where Can I find it? Please..
      • trebor
        trebor commented
        Editing a comment
        Let's hope someone will do one
      Can I use one of another TV box with the same specs?
        Hi, can somedy tell for sure does it have DDR4 or DDR3 memory? gearbest tells DDR4, banggood tells DDR3.
        Does it have navigation bar and status bar?
        • trebor
          trebor commented
          Editing a comment
          And as written :
          UI looks kind Groovy and clean/not busy, No Root, No task/notification bar (upper and Lower)
        If you looked at the pictures of the PCB it clearly is printed LPDDR4 next to the SKhynix Ram chip.
        That doesn't mean if you buy the cheapest version, example 2GB ram with 16GB storage, that it will also have same LPDDR4 because usually the cheapest model will have cheaper hardware and Ram chips could be changed for the cheaper model. So always purchase the top model option for a device, in this case I believe it is the 4GB/64GB like the one tested in this review.
          can I usew this rom in this model?
          [ROM] POISON TV GT1_MINI2 Changelog V3.1 -Nov 2 2019 Released -Based on Beelink 906P0/201P0 Firmware -AndroidTV Version -Stock Recovery -Optimized Systemui -Overclocked Gpu -Tweak System -Fixed Iptv reboot issue -Fixed Glitch in ui -added even more remote layouts:) -Fixed conflict of tweaks i had in previous versions -Poison
            I'm also interested in a new rom because stock one can't install apps from appstore
              I have tried some for diferent brands but they dont work.
              if you find one that work can you sent it to me?
              I will do the same for you..
              best regards
                best regards
                This one worked. I found it in xda forum:
                Originally Posted by Goce_MKD
                Newest firmware https: // drive.google. com / file / d / 1RgQkfzHFqyZOfaKdT4MS6tfkFPB-yNmI / view
                Firmware update guide https: // youtube. com / watch?v=dAIsBHyWdHA
                USB Burning Tool https: // my.pcloud.com / publink / show?code=XZYkW4kZ9LgFOxuvfQkGwQGb7hQrdj1mTLu7
                Remove space in links
                  Anyone have try this rom ? i need ATV rom
                    https://forum.freaktab.com/forum/tv-...tv-build/page3
                    I did and didn't work
                      That firmware is the same as the one who came with the device or does it have something new/different? And which method did you use to install it? Toothpick? Other?
                      Thanks for your help!
                      This box could probably improve with some kind of modded firmware. But, even without it, it does work well, i.e. it is reasonably fast. The most annoying thing is that many apps will not install via Play Store. But, using alternative methods we can install lots of stuff.
                        I used the toothpic method. the firmware has a more recent version of android and now can install apps from app store
                          I cant boot it into the recovery mode
