Well I reformated my SD card. Then redownloaded the recovery and the kyser root thing and put both on the sd card. Turned it on into recovery and flashed the kyser root thing and now after setting it up from scratch again, the market will not update to the newest one. Also nothing will download on the market. It just says downloading but it never stops. Please help me figure this out. Oh and when I turn the tablet off, I have to set it up like it is brand new again. TIA.
NextBook Premium 8 IPS ( NEXT8HI8G ) rooting.
Recovery added and flashed root....
Originally posted by moonsbabe View PostWell I reformated my SD card. Then redownloaded the recovery and the kyser root thing and put both on the sd card. Turned it on into recovery and flashed the kyser root thing and now after setting it up from scratch again, the market will not update to the newest one. Also nothing will download on the market. It just says downloading but it never stops. Please help me figure this out. Oh and when I turn the tablet off, I have to set it up like it is brand new again. TIA.
Reboot to recovery
Wipe Cache (Twice)
Reboot to Android and test
If that didn't fix it, it's probably the dalvik cache. Unfortunately davlik cache is stored on data and the only way to wipe it is wipe data.
Reboot to recovery
Wipe Cache (Twice)
Wipe Data / Factory Reset (Twice)
You may have to do this more than once until it works right, especially if you have a failing block in your NAND memory. You may have better results if you remove the external SD card temporarily and use the stock internal recovery to wipe cache and data.Freaktab Rom Developer
Originally posted by shaunmt View PostYour cache or dalvik cache are corrupted.
Reboot to recovery
Wipe Cache (Twice)
Reboot to recovery
Wipe Cache (Twice)
Shell Shocker at Newegg for $80 - Today only (03-11-2014) (NX008HI8G)
Nextbook 8" Android Tablet - Dual Core 1.50Ghz 1GB RAM 8GB Flash IPS Display Android 4.1 GMS (NX008HI8G)
Sale starts at 10am PT.
If anybody has rooted this tablet using Cydia Impactor, let us know. Reports earlier in this thread (months ago) said it did not work.
There are currently 4830 users online. 1 members and 4829 guests.
