X96 Air Amlogic S905X3 Android 9.0 Media Player 4/32GB
They say: in the Highlights
Amlogic S905X3
Amlogic S905X3 applies quad-core Cortex-A55 processors, which is described as an "advanced application processor designed for hybrid OTT/ IP Set-Top Box (STB) and high-end media box applications. The Cortex-A55 cores deliver up to twice the performance compared to Cortex-A53 in memory benchmarks, and a more typical 20 to 30% performance improvement for common tasks at the same frequency.
8K UHD Resolution
True 8k picture resolution can be as high as 7680*4320 to achieve 16 times of 1080p picture accuracy.
Android 9.0 OS
It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
Enjoy Big Screen
Supports XBMC, DLNA, Miracast, Airplay. You can play games and watch movies on the big screen.
Lets have a look see:
The Box:
What is in the Box:
Ports:
Display:
Remove the base:
Out with the PCB
Geekbuying
More soon or later
