[ROM] Beelink GT1-Mini2 ALVATECH Standard Android (9.0 Pie) S905X3
Hi, i have a problem with:
Tip (1.)
MAGISK INSTALL & HOW TO PASS SAFETYNET.
Section (A.):
Now open Magisk Manager again and then go to the downloads section from the top left menu, then in the top right corner in the search bar type SafetyPatch then download and install the module.
I have no SafetyPatch in Download section of the MagiskManager.
Can you help me with that?
Thx
Anyone knows what files I need to edit in order to make the device able to be navigated using a different IR remote ? I found that I could use this ROM with an emulated Minix Remote on my smart phone. However, pressing on handphone is not something I enjoy, I still prefer to use a physical IR remote. I happen to have one IR remote which can perform arrow down. All other keys are not navigating correctly. Which file should I edit to remapped to the correct key ?
There are currently 2853 users online. 1 members and 2852 guests.
