Magicsee N6 Plus Android 9.0 4G + 128G Dual WiFi, Gig Lan:
    Amlogic S922X, Arm Mali TM-G52 MP6,
    2.4GHz + 5GHz Dual-Band WiFi, H.264, H.265, Support 4K 60fps
    Click image for larger version  Name:	20200109142135_83628.jpg Views:	0 Size:	71.5 KB ID:	794864Magicsee N6 Plus Descriptions as found:
    A Device Leads You to the Wonderful World
    Are you looking for a device integrating various entertainment activities to enrich your visual and auditory experience at home? Here comes the Magicsee N6 Plus TV box, which provides massive videos and games without buffering or breaking down, making every moment enjoyable. With the high-performance software and hardware, Magicsee N6 Plus TV box is always to lead you into a magical world once you turn it on.
    Main Features:
    Rapid and Responsive Running
    Equipped with the high-performance Amlogic S922X Hexa-core, Magicsee N6 Plus TV box runs fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games.
    Great Compatibility
    Adapting the Android 9.0 operation system, Magicsee N6 Plus is compatible with more software, games, and applications, improving users' experience.
    Unparalleled Video Display
    4GB DDR4 allows you to display high-definition video smoothly, and eMMC 128GB storage memory supports you to download massive resources from the internet, such as movies, software, and applications.
    Stable and Fast Data Transmission
    2.4G + 5G dual-WiFi and 1000Mbps LAN run internet, streaming and audio perfectly without jerking, which allows you to play 4K @ 60fps, 3D and H.256 videos smoothly.
    Convenient to Control
    Speak to the 2.4G voice remote control, and it will operate the TV box based on your demand. And support air mouse function.
    Screen Rotation
    We added portrait and reversed modes for rotation screen, It will be useful if you dome non-standard application or digital.
    Hardware Monitor
    CPU, temperature, network, load ram real time performance, each one is under control: CPU load, internet speed, RAM usage, temperature.
    Dynamic HDR Support
    Dynamic HDR support ensures every moment of a video is displayed at its ideal values for depth, detail, brightness, contrast, and wider color gamuts-on a scene-by-scene or even a frame-by-frame basis.
    Parameters:
    CPU: Amlogic S922X Quad core ARM Cortex-A73+Dual core ARM Cortex-A53
    GPU: Arm Mali TM-G52 MP6 ( 6EE )
    System OS: Android 9.0
    RAM Type: DDR4
    RAM: 4GB
    ROM: 32 or 64 GB
    Wi-Fi: 2.4GHz / 5GHz, IEEE 802.11a / b / g / n / ac, 2 x 2 MIMO
    BT: 4.1
    Ethernet: 1000Mbps
    Gearbest
    Bit of a deal going on here
    GEARBEST Exclusive Launch: $98.99, First 100 Units ONLY (https://www.gearbest.com/tv-box/pp_009679176342.html?wid=1349303&lkid=78315127) www.gearbest.com Magicsee N6 Plus Android 9.0 4G + 128G Smart TV Box Price?$129.99 Desposit?$10 Desposit save:$31 (1.17 00:00:00 -2.10 7:59:59) Final Price:$98.99 100 orders only Time for
    How Good or bad is up to You
      Thanks to Gearbest we can have alook at
      Magicsee N6 Plus Android 9.0 4G + 128G Smart TV Box - Black 4GB DDR4 + 128GB ROM
      Information as Found:
      A Device Leads You
      Main Features:
      Great Compatibility
      Screen Rotation
      Hardware Monitor
      CPU, temperature, network, load ram realtime performance, each one is under control: CPU load, internet speed, RAM usage, temperature.
      Dynamic HDR Support
      Parameters:
      RAM Type: DDR4
      RAM: 4GB
      ROM: 128GB
      BT: 4.1
      Ethernet: 1000Mbps
      Lets Have a look:
      Box:
      What is in the Box
      Ports
      Remove the base
      Out with the PCB
      https://www.gearbest.com/tv-box/pp_0...&lkid=78642181
      More soon:
        Moving along we can start to have a close look at what we have here: again thanks Gearbest
        Hardware is looking OK,
        We have S/PIDF, RTC Battery, Clock, External Antenna, and 4/128GB HUGE
        Also included is the Voice Remote
        A few extra in MG settings
        Root Switch, Screen Rotation Force, Hardware monitor
        Start up all good no weird stuff.
        The connection to WiFi or Ethernet tested good.
        Google Login easy, a few apps to update, so far so good.
        A groovy looking UI home screen and a few features to be found in settings
        Lets have a first look:
        UI
        Installed Apps:
        Easy to change the back Ground:
        Settings:
        MG Settings:
        Only thing I don't like so far, we have the Clock that shows all the features
        Then this super bright burn your Retina Blue LED, Nothing a small Piece of black tape cant fix
        More Soon
          More to look at, some bench test and more info:
          Antutu: Depending on what version you run you will get different answers:
          Again use only you as a guide:
          The Go version:
          Or the 3D version:
          Ram and Storage Truth:
          SD Card test: Looking good
          DRM Info L3:
          CPU-Z
          After more tinkering what we have overall is a fairly Good kinda of Unit,
          A custom Rom would make it better, not sure if any of the Devs will have/get one one these.
          Vulcan appears not activated as yet, or reported by software
          Remote works well and squirrel mouse (all over the place)
          Remote appears to be always in voice activated (listening) mode at present with Hello Google
          Most else appears to work well as it should may need a few updates to make it 100%
          There are currently no OTA seen and nothing much on Magicsee website as far as updates
          Price looking OK for what get lets hope and they can do some magic with updates and see some improvements
          There is a few 922x around firmware should be able to keep up (we can only hope)
          Using a 12v 1.5amp power pack should be ample but if your going to attache HDD's a powered hub or HDD I recommend
          if the older spinner types, maybe ok with SSD,
          BUT more Amps is always better.
          And just remember that bit black tape on that LED, its bright
          Most now should be aware of some limitations of Android well mentioned on Freaktab in most box threads.
          What it can and cant do as opposed to
          what the user thinks it should be able to do and what is advertised
          May add a few more bits as I tinker on the bench for awhile.
            Magicsee N6 Plus Android 9.0 4G, Currently available in 4GB /32 or 64GB
            Specification
            Brand: Magicsee
            Model: N6 Plus
            Type: TV Box
            System: Android 9.0
            CPU: Amlogic S922X
            Core: Hexa Core
            RAM: 4G RAM
            RAM Type: DDR4
            ROM: 32G,64G
            Max. Extended Capacity: TF card up to 64GB (not included)
            Color: Black
            Gearbest
