Multiboot development pack
    Want to develop your own Linux kernel? Cook your own ROMs? Be able to boot both Android and Linux? Then try my multiboot development pack https://docs.google.com/file/d/0B99O...FJGdnZoOVhpOGM
    Hopefully this contains everything you need to get you started, and then up and running, and sets you up for the future.
    It includes instructions, config, pseudo makefiles, tools, initramfs, software and links to sources - everything you want in a single place.
    See https://plus.google.com/109451178006...ts/QALQDkRpN6V for further details.
    Much thanks, linuxium. I'm going to give this a try.
    T428
      Re: Multiboot development pack
      Thanks a lot, I will play with this tools.
      leolas.
      My devices:
      Gearbest.com)
        I'm having difficulty following the instructions.
        I get an error at :-
        6. ....
        cp git-3188-SRC-AP6210.config git-3188-SRC-AP6210/kernel_ruikemei/.config
        and thereafter.
        Anybody managed to complete the instructions?
          6. ....
          and thereafter.
          What is the error? Did step 5 complete correctly? Did you do the first cp of step 6?
            My error is :-
            cp: cannot create regular file `git-3188-SRC-AP6210/kernel_ruikemei/.config': No such file or directory
            And it is probably a simple error on my part - but bear with me!
              My error is :-
              Did step 5 (git clone https://github.com/linuxium/3188-SRC-AP6210 git-3188-SRC-AP6210) complete successfully?
              What happens if you so a "ls -ld git-3188-SRC-AP6210" and a "ls -ld git-3188-SRC-AP6210/kernel_ruikemei" and a "ls -l git-3188-SRC-AP6210"?
              The error implies that there is no "kernel_ruikemei" sub-directory in "git-3188-SRC-AP6210" which points to a git failure. "git clone" will download the source into the local directory "git-3188-SRC-AP6210" which means that "git-3188-SRC-AP6210" will result in a whole directory tree within it which includes "kernel_ruikemei" which in turn contains "arch", "drivers", "kernel" etc.. If you are downloading your source from somewhere else, then perhaps the structure of the source directory is different?
                Hello Ian,
                your boot-partition-init way is a very nice solution to get multiboot. Thanks!
                My device is a MK808-B, equiped with Linux (Kernel 3.0.36 Galland, Picuntu 4.4 RFS on SD) and Android (Finless Rom 2.1 on NAND).
                I just took Finless boot720.img, extracted it and did the steps from READ_ME:
                - renamed & linked 'init' binary
                - copied your 'init' script
                - copied 'initramfs-3.0.36+multiboot/bin' and 'initramfs-3.0.36+multiboot/lib' folders
                Multiboot works fine, but as you may guess, display console output doesn't work and I'm searching for a way how to compile the called modules for my kernel.
                snip from init line 68-72:
                # Insert FRAMEBUFFER modules to provide console display
                insmod /lib/modules/3.0.36+/kernel/drivers/video/console/softcursor.ko
                insmod /lib/modules/3.0.36+/kernel/drivers/video/console/bitblit.ko
                insmod /lib/modules/3.0.36+/kernel/drivers/video/console/font.ko
                insmod /lib/modules/3.0.36+/kernel/drivers/video/console/fbcon.ko
                My /lib/modules/3.0.36+/kernel/drivers/video/ folder contains only a folder called 'rockchip' with disp_ump.ko
                Here is my config:
ID:	430962Click image for larger version
                Could you help me to get these modules compiled?
                ̶i̶̶s̶̶ ̶̶i̶̶t̶̶ ̶̶m̶̶a̶̶y̶̶b̶̶e̶̶ ̶"̶r̶̶k̶̶_̶̶l̶̶v̶̶d̶̶s̶̶ ̶̶s̶̶u̶̶p̶̶p̶̶o̶̶r̶̶t̶"̶ ̶̶t̶̶h̶̶a̶̶t̶̶ ̶̶n̶̶e̶̶e̶̶d̶̶s̶̶ ̶̶t̶̶o̶̶ ̶̶b̶̶e̶̶ ̶̶e̶̶n̶̶a̶̶b̶̶l̶̶e̶̶d̶̶?̶
                Edit: checked your config and "RK_LVDS support" is disabled, drop that question.
                Conrad
                  Originally posted by conred View Post
                  Hello Ian,
                  Here is my config:
                  [ATTACH=CONFIG]3608[/ATTACH][ATTACH=CONFIG]3609[/ATTACH]
                  Conrad
                  Change your "Framebuffer console support" from '*' to 'M" and then when you compile with "modules"/"modules_install" the .ko files wll be in your "output/lib/modules/3.0.36+" directory structure so you can then copy to the relevant "/lib" directories.
                    Yes, after reading the first words it came to mind, I should compile them as modules, not built-in.
                    Thanks for hunting out this newbie issue!
                      My little trial using the console modules for Galland's kernel doesn't work. Well, it could not work.
                      Having Finless Android-Kernel flashed to kernel partition and Linux-Kernel to recovery, it would require to have the console video modules for Android-Kernel to get the init script working, right?
                      Could you shortly explain how you compiled the modules that work with Rikomagic's ROM Android Kernel?
                      And thanks a lot for writing all this documentation, it's a nice learning pack for me.
                      Conrad
                        Conrad
                        See step 18 - the console modules are only used in initramfs-3.0.36 and not in multiboot
                          " rk30xxnand_ko" help
                          Hello I build a kernel with option -mfloat-abi = hard kernel works.
                          Does not work I rk30xxnand_ko module.
                          I need information -?
                          how do I create this module rk30xxnand_ko which I need to change in ".config" that option.
                          Help appreciated.
                          flycast mk809iii
                            Help appreciated.
                            rk30xxnand_ko is currently only available as a binary from Rockchip and they do not provide the source. Are you compiling locally? Why not cross compile by installing the GNU C compiler for armhf architecture (gcc-arm-linux-gnueabihf) and then "make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-"?
                              Yes of course i have cross compile with Linaro 4.7 armhf much of the kernel is always set to rigidly.
                              Check in:
                              > Kernel-3188/arch/arm/Makefile
                              "KBUILD_CFLAGS + = $ (CFLAGS_ABI) $ (CFLAGS_THUMB2) $ (arch-y) $ (tune-y) $ (call cc-option,-mshort-load-bytes, $ (call cc-option,-malignment-traps, )) MSoft-float-Uarm
                              KBUILD_AFLAGS + = $ (CFLAGS_ABI) $ (AFLAGS_THUMB2) $ (arch-y) $ (tune-y)-include asm / unified.h-MSoft-float "
                              You can not add to cross compile flag-mfloat-abi = hard, always pop up error.
                              So the kernel is default "-softfp" only world you can build with-hardfp.
                              • team of Radxa Rock also will not get the code?
                              flycast mk809iii
