Allwinner H3 Projector with custom Android 4.4.2 called Levision - Need help
    Hi Guys,
    I have a Chinese Projector called a Magic-Image M1 with Android 4.4.2.I tried to install TWRP bootrecovery onto the device and it bricked it! It uses a H3 Allwinner hardware board running a flavor of Android they made them self's called Levision on 4.4.2. I managed to contact them and after a HUGH struggle to send me the
    firmware, they eventually did! But here is the problem, they send it in OTA ZIP update format with these files listed,
    2008/02/29 10:33 12 083 200 boot.img
    2008/02/29 10:33 32 768 boot0_nand.fex
    2008/02/29 10:33 32 768 boot0_sdcard.fex
    2008/02/29 10:33 7 209 984 bootloader.fex
    2008/02/29 10:33 131 072 env.fex
    2008/02/29 10:33 9 075 file_contexts
    2019/03/17 17:22 <DIR> META-INF
    2019/03/17 14:01 <DIR> recovery
    2019/03/15 18:57 13 012 992 recovery.img
    system
    2008/02/29 10:33 933 888 uboot_nand.fex
    2008/02/29 10:33 933 888 uboot_sdcard.fex
    Below is the error I extracted from the UART debug port via putty,
    Starting kernel ...
    [sun8i_fixup]: From boot, get meminfo:
    S?art: 0x40000000
    ion_carveout reserve: 160m@0 300m@0 130m@1 200m@1
    ion_reserve_select: ion chipid [0x2c00081!
    ion_reserve_common: ion reserve: [0x4d400000, 0x60000000]!
    [ 0.770060] ls_fetch_sysconfig_para: type err device_used = -1064009776.
    [ 0.782056] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
    [ 0.802360] sunxi_oops: heming add OOPS_INFO_ADDR = -20
    [ 0.957791] gpio-keys-polled gpio-keys-polled.0: unable to claim gpio 16, err=-16
    [ 0.966275] ths_fetch_sysconfig_para: type err device_used = 1.
    [ 0.981586] init: init proc start
    [ 1.049087] init: open path: /dev/bus/usb/001/001
    [ 1.240250] init: open path: /dev/bus/usb/002/002
    [ 1.442023] init: open path: /dev/bus/usb/002/001
    [ 1.710240] init: open path: /dev/bus/usb/003/002
    [ 1.932304] init: start e2fsck listening...
    [ 1.951050] init: open path: /dev/bus/usb/002/002
    [ 1.956750] EXT4-fs (nandm): VFS: Can't find ext4 filesystem
    [ 2.010218] fs_mgr: begin to format ext4 buffer : /dev/block/nandm
    [ 2.055305] init: open path: /dev/bus/usb/003/001
    [ 2.310516] init: open path: /dev/bus/usb/003/002
    [ 2.564758] init: open path: /dev/bus/usb/004/001
    [ 4.838517] fs_mgr: finish format to ext4 :/dev/block/nandm
    [ 4.886940] EXT4-fs (nandn): VFS: Can't find ext4 filesystem
    [ 4.937111] init: C_IN_START
    [ 4.940154] init: path = /dev/block/by-name/cache
    [ 4.960157] fs_mgr: begin to format ext4 buffer : /dev/block/nandn Z2 battery get level is 100.
    [ 24.1132v2] fs_mor: finish format to ext4 :/dev/block/nandn
    [ 24.145791] FAT-fs (nandi): bogus logical sector size 65535
    [ 24.230097] fs_?gr: start ?rmat /de?/block/by-name/Reserve0
    [ 24.236512] fs_mgr: wait for format /dev/block/by-name/Reserve0
    [ 24.236773] fs_mgr: fork to format /dev/block/by-name/Reserve0 fileSystem: Fat16
    [ ?4>251814] FA?-fs (nandi): bogus logical sector size 65535
    [ 24.310114] fs_mgr: Cannot mont filesystem on /dev/block/by-name/Reserve0 at /mnt/Reserve0
    [ 24.319425] init: fs_mgr_mount_all returned an error
    [ 24.325607] init: defined DONT_SHOW_INITLOGO
    [ 24?331069] ini?: /sys/cln?
    [ 24.331108] init: dont need format /dev/block/by-name/private
    [ 24.337216] init: skipping insecure file '/system/vendor/modules/mali.ko'
    [ 24.337295] init: skipping?insecure file '/system/vendor/modules/sunxi-ir-rx.ko'
    [ 24.337351] init: skipping insecure file '/system/vendor/modules/sunxi-keyboard.ko'
    [ 24.337419] init: skipping insecure file '/system/vendor/modules/gpio-sunxi.ko'
    [ 24.375922] init: The device is not low memory 1002
    [ 24.381339] init: init_disp=0x20b0404, type=2, id=1
    [ 24.386980] init: disp=1,type=2,mode=11
    [ 24.419164] init: skipping insecure file '/system/build.prop'
    [ 24.426149] init: get_disp_policy: for modify confi?s.
    [ 24.431877] init: untracked pid 118 exited
    [ 24.436882] init: skipping insecure file '/system/vendor/modules/bt_sleep.ko'
    [ 24.444910] init: skipping insecure file '/system/vendor/modules/asix.ko'
    [ 24.478503] healthd: No charger supplies found
    [ 24.600448] init: cannot find '/system/bin/sh', disabling 'console'
    [ 24.607585] android_usb: already disable?
    [ 24.947444] init: C_IN_START
    [ 24.9505r4] init: path = /dev/block/by-name/UDISK
    [ 25.041200] init: cannot execve('/system/etc/install-recovery.sh'): No such f[ 26.232861] init: untracked pid 177 exited
    I tried flashing it with PhoenixPro but it does not work. I am a NOOB with this. Can someone please help to get it working to be flashed via PhoenixPro or via SD port?
    Bump
