Beelink GT1 Mini 2 - the microphone on the g10-g30 remote does not work
Originally posted by Talory View Postwhat files to replace, fix, so that the microphone works on the g10-g30 remote.
Rscy, that is the nice thing about the G30s running on this Mini2, you only have to depress the "mic" button and let go of it, don't have to keep it depressed as you talk. Ont the other hand, with the stock "voice" remote, you have to depress the "mic" button and KEEP it depressed as you talk.....MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
stock firmware. I don’t know what to add to make it work. probably need a *.so module?
Ask on this thread, or better yet, try his ROM........
Please read the entire first post before asking questions. Thank you. This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT1-Mini2 ROM. This ROM was made from Beelink's stock ROM if you're look for Android TV 9.0 ROM for this box look here (https://forum.freaktab.com/forum/tvMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
stock firmware. I don’t know what to add to make it work. probably need a *.ko module?
Thank you,
AlvatechLast edited by ALVATECH; 11 January 2020, 05:38.
My g30 remote's microphone stopped working a couple of days ago actually. And yeah I know that I do not have to keep the mic button pressed while I am talking, as it actually worked perfectly until the last sunday. I just do no understand what happened, it was working, and then just suddenly it would stop. I actually thought that I have to change the battery however nothing actually changed after I have changed it. I guess I will be looking for a solution on a the site where I found all the best microphone for vocals reviews. Hope they can help me actually.Last edited by Laratrak; 21 January 2021, 17:00.
There are currently 1493 users online. 0 members and 1493 guests.
