LiveSuite flash procedure video on YouTube - Onda ICS shown but same for all
    NOTE WARNING WARNING WARNING
    At this point we do not have an original ROM for the Polaroid. You can get your system back mostly to normal by flashing the Gingerbread Onda Rom but it does not reflash the nanda partition (Via KK, the developer that made the clockwork recovery that works to a point). I did try yesterday and made a clone of my original in functionality that at least seemed to work, but again use at your own risk.
    Second note, so far in my preliminary testing the Gingerbread ROM overclocked to 1.2GHZ has had the best performance.
    http://youtu.be/oL5KnVH6inQ
    Hold your horses on downloading folks, I just found out there are newer versions out there
    I will get them updated shortly after getting them in from Onda. In the mean time if you want to try to look youself here is the updated links from Onda (some translation required):
      http://www.onda.cn/MP3/ProductInfo.a...tId=166&d=down
      I can host them here if you guys like but you needs to either put them in a dropbox or I can give you FTP info to upload them here. I wont go to 4shared for many reasons.
        Testing out the newer ROM's now
        I can pull the 4shared links if you want Finless. Only went with them because so far they at least had not made it easy for me to download a ton of misc crap, unlike many of the other ones that are totally loaded up with links to download adware. the files I have are all between 150 and 300 Meg (The ICS ones are bigger of course)
        Side note just got done running the AnTuTu on the V5 ICS ROM clocked to 1.2Ghz (not ready for us, it inverts the screen all the time unless it is locked in settings, but I figured it was already on so might as well) is 3481.
          two question
          just two can this be applied to the polaroid pmid70x if not does anyone know where i can find a link to a site that has it
