Model: ZIDOO_X8 / X9S / X10
Version number: v2.1.36
Changelog
(From here, translation via Google Translate.)
(original text below) / (???????? ????)
System
1. Add the "Information" button on the remote control to display the current HDMI output information
2. Optimize DLNA projection function
2. Optimize system stability
File manager
1. Fix the problem that the same share name is displayed in NFS
2. Cancel the top navigation category and add the list rotation function
3. Added CD disc insertion tips
4. Optimize sorting function (save separately by path)
5. Added the function of pressing "Popup" to return to the top of the list
7. Modify the problem that the volume label does not display more than 20 characters
Poster wall
1. Optimize the display of the details interface and the movie video
2. Optimize segmented video scanning
3. Optimize scanning to solve the problem that stopping scanning during scanning may cause unmatched videos to not match properly when continuing scanning
4. Solve the problem that the child lock set is not displayed synchronously after the movie rating is initially set
5. Increase the HDR corner mark (scanned videos will not be displayed)
6. Optimize file name recognition
7. Optimize application stability
8. Optimize bracket processing for title recognition
9. Added trailer filter filtering, the word 'trailer' in the file name will no longer be scanned
10. Optimize the NFS mount method
11. Fix the problem that the background service causes the setup wizard language to be incorrect
12. Fixed the problem of disordered video in the folder video list interface
13. Fixed the problem that poster information cannot be obtained based on the file path
14. Fixed the problem that the total number of videos on the device does not change after moving the video out of the poster wall
15. Clear device and delete device will remove related video information from database
16. Fixed the issue that the poster does not refresh after modifying the rating of the child lock
17. Child lock setting interface adds function description and child lock reset function
18. Optimize the collection function
19. Fixed the issue that playback records cannot be saved when playing NFS source
20. NFO added sort title field support, only use this field for sorting in movie collection interface
music player
1. Optimize folder browsing function
2. Add CD playback function (requires external optical drive)
3. Optimize the sorting function
4. Optimize the calculation method of scanning progress
5. Optimize track identification for SACD and CUE albums
6. Improved the interface of obtaining track list, and solved the problem that the mobile phone cannot control the CUE / DSF track list of temporary list
7. Modify the time display format of CUE to keep the same with SACD
8. Optimize focus control logic to solve the problem of focus flicker
9. Modify the recording method of the playlist to solve the problem that the last song in the random play mode will be rerandom.
10. Added screen saver function in play details interface
11. Fixed an issue where the list interface displayed an error after the grid layout removed the list
12. Fixed the problem of getting albums when playing music from file manager
13. Fixed the problem that the lyrics could not be closed without playing the details interface
14. Fixed the problem that sometimes the detailed interface picture cannot be obtained
15. Added automatic full-screen playback switch
16. Added music file information display to the list
17. Solve the problem that search interface focus may be lost
18. Fix the problem that the song is cut abnormally in the playback interface
19. Modify singer details interface
-Add album sub-categories, you can directly enter album details from the list
-Add picture subclasses, you can set the default, delete and add operations for pictures
-Add details sub-category, you can browse all the information of the singer
20. Add "View Artist" and "View Album" functions
21. Add song names that do not match the file name "track + number"
22. Fixed the problem of flashing back when pressing the "Home" key in the folder song interface
23. Fix the problem that Bluetooth remote control connection stops playing
24. Add multi-folder scanning. The abnormality will be displayed after the scanning is completed, and the normal display will be restored after all scanning
25. Fix the problem that the time of the song displayed on the front panel is incorrect
26. Fix the problem that the sample rate of the playback details interface is incorrect.
27. Fix the problem that some DTS-CDs cannot be played
Local player
1. Add sequence play function
2. Fixed the issue that subtitles in Polish are displayed as Portuguese
3. Optimize subtitle download function
4. Optimize the problem that DVD cannot select chapters
5. Optimize ASS subtitle display
6. Fixed the problem that the srt subtitle space is not displayed completely
7. Fixed the problem of displaying the DVD folder format and file name abnormally
Blu-ray navigation
1. Added the function of subtitle track list displayed by shortcut keys
2. Optimize subtitle download function
3. Fixed the problem of incomplete display of srt subtitle space
Quick settings
1. Modify DMR switch settings
2. Add video sequence playback function
Picture manager
1. When optimizing the slideshow, the picture is blurred
the weather
1. Optimize the problem that the weather is not available in some cities
Mobile APP (need to update mobile app v.1.5.5)
1. Add audio offset setting in the setting interface
2. Folder browsing function has been added to the music device interface
3. Application interface adds sorting function
4. Fixed the problem that the same device is repeatedly added to the music device interface
5. Fixed the issue that the CUE / DSF track list cannot be obtained from the temporary list songs
6. Optimize the problem that the application interface icon is not displayed
7. Optimize poster wall interface display
8. Solve the problem that the file management is affected by the search bar, and it will return to the upper directory when rescanning SMB or NFS
9. File manager adds list refresh function
10. File Manager adds CD-ROM drive list
Posted on @ZidooNews
Gofile Mirror: https://gofile.io/?c=1yjDPM
How to upgrade: http://bit.ly/2RgPFA6
MD5 Hash: 766565401970CE5870A0A8E135C5B863
Have a fun!
Source:
http://forum.zidoo.tv/index.php?thre...v2-1-36.66499/
