com.ufo.minor test app keep popping up
Hi dear friends . one of my android tv box ingected with test app it keep popping up and being installed automatically . I did uninstalled so many time . app name is test and made by com..ufo.minor. it is one of the cryptocurrency minor app. i did factory reset , tuned off usb debug in developer options but no lock ? looking some help.Tags: None
hmm..
if you have root.. then use a root uninstall system app ( like titanium backup )
if you have root.. total commander then search apk.. delete apk from internal nand/emmc
if you have root... you can also freeze the app ( like with titanium backup or frozen )
If you don't have root.. you might still "disable" the app using settings/apps/name app
if all fails.. try a different firmware
goodluck
There are currently 1776 users online. 1 members and 1775 guests.
