[DELETED]
Originally posted by FenirexS View PostHi, I need to know if anyone has the remote.conf file for the beelink gt king pro. I am using LibreELEC on the sd card and would like to find a way to remap the power button to give it another function since it uses ir. I read on that forum that the basic model is already configured and editable.
https://translate.google.com/transla...ml&prev=search
I tried to use it the same file but it doesn't work. I read that you need to find the "factory code" of the remote in order to remap the power button. So I would like to know if anyone has already configured it.
If possible could you share the device tree file you use?
I tried many versions but seem buggy .
There are currently 2524 users online. 1 members and 2523 guests.
