here the ATVExperience rom to better support the Alfawise X 3200:
This rom adds the wifi/BT support to the ATVE rom (S905X_atvXperience_2FF 1G+2G version). If you want to know the features of the ATVE rom, please visit the website.
If you want to know more about this "smart" projector, please read here: https://androidpctv.com/review-alfawise-x-3200/
Hereunder the main specs of this device:
AMLogic S905X Cortex-A53 Quad Core 2.0GHz
GPU Mali-450MP
RAM 1 GB DDR3
Storage 8 GB eMMc
WiFi WiFi b/g/n
Bluetooth 4.0
This projector doesn't have an available stock rom, the original firmware is based on Android 6 and it's poorly optimized. With this rom, you can upgrade to Android 7 with good perfomances and stability.
The process to burn the rom is strightfoward:
0) Activate the usb debugging mode on the Alfawise
1) Amlogic USB Burning tool + male/male usb cable from the pc to 1 of the usb ports of the X 3200
2) Open USB burning tool and load the image file: press start.
3) plug the power and usb cables (USB 2 port is better) and turn the X 3200 on (no reset button to push)
4) Wait until the process is over
Knwon issues:
-IR remote doesn't work. Workaroud: ATVE supports Android Remote, mouses and keyboards. Just plug them to the usb port of the projector.
