X96s very simple ATV 9.0 Pie firmware based on latest stock firmware
    This is simple ATV9 firmware based on latest stock firmware X96S_V311_P_20191021-2013, it start without Google account.
    Features:
    • support start scripts located at /etc/init.d/
    • root and SuperSU patched user anpaza (4PDA)
    • AFRD
    • build.prop tweaks
    • AppDrawer and some apps on main screen
    • picture optimization
    • double home click shows tasks
    • and many other simple features
    screenshot
    Click image for larger version  Name:	Screenshot_20200121-150259.png Views:	160 Size:	328.6 KB ID:	795950
    Image for USB Burning tool
    Download for rev. X96s_P link
    Download for rev. X96s_V311_P link
    What is the screenshot of? That would be wonderful if it's a new & better launcher for the x96s.
      It's a standard ATV 9 Leanback launcher .
        Thanks, i will give it a try, i might have hardware that wont let it work.
          Hi lekha7777, this ROM was manufactured by DaivietPDA ?
          I have look on the site of "DaivietPDA", but I can't find it.
          Can you, give the source of this ROM ?
          Thanks in advance for the reply.
            Yes, SYSTEM from davietPDA with tweaks and other stock partions. I dont have source code, but I have it SYSTEM build
              lekha7777,
              1) I was not talking about the source code, but where did you find this ROM ?
              2) did you test this ROM ?
                Mr nvuphi share his twrp backup for x96air here http://4pda.ru/forum/index.php?showt...ost&p=91747366
                I used this system partition for build custom roms for more boxes with my mods and tweaks.
                this rom tested by me and other x96s owners. You may read about using this rom here
                  Hello! How to install this firmware?
                    http://4pda.ru/forum/index.php?showt...ost&p=93116723
                      Features:
                      • AFRD
                      • build.prop tweaks
                      screenshot
                      Image for USB Burning tool https://mega.nz/#!sE03EK5a!ywbJofjqz...9DjwhmBxXiBBJc
                        Try searching string "usb burning tool manual"
                          Can I give a description of the flashing here?
                            switch off stick.
                            in UBT File - import image , wait for checking, Start, connect x96s to usb port, wait for flashing complete.
                            Warning All your user data on stick will be lost.
                              Has anyone tried this new firmware yet? and does it work?
