wifi hk 5230 // BCM4330 (AP6330)-802.11abgn+BT4.0+HS und FM Transceiver (according to Chinese source H96Max X3蓝版固件,解决刷入slimbox后wifi 蓝牙不可用的问题_外贸原生安卓盒子_ZNDS
bt
ethernet hb1601snl (10/100)
Android TV 9 Soldiaz Port HK1 Play with wifi and bt support.
Pure SuperCeleron.Multi-S905x2.Pie.ATV.20191004 would not run on it.
Based on
Official Stock: u241.S905X2.HK1_PLAY_noroot_4G_100M_9.0.2019.10.28 .15.31 and SuperCeleron.Multi-S905x2.Pie.ATV.20191004
https://drive.google.com/file/d/1oPH...ew?usp=sharing
Minixfreak OS Soldiaz port (ATV9)
https://drive.google.com/file/d/1K6u...6ajHiPZoJ/view
Spartan OS
Spartan OS 5 and the h96x2 build runs without modification: https://mega.nz/folder/8ph0DCzI#8ufSqijbc9NQL8NZJSqy7w
Original Stock
(no root)
https://drive.google.com/file/d/1Kmm...Fb62BQQUk/view
(root)
https://mega.nz/#!dUFVAA6L!idEPGZNo6HMZgg-lpzaggEUVUidK-TiDE2-VerQB0VY
In case you mix sth up, shorten these:
