unknown box rk3229
unknown box rk3229
Hello everybody. there is a 1/8 box. with version 7.1. from provider with 1 application. I want to flash a normal os. but on all versions gives an error test device fail. I can not erase or write. how do i flash a box?You may only view thumbnails in this gallery. This gallery has 4 photos.4 PhotosTags: None
Originally posted by nezlos View PostHello everybody. there is a 1/8 box. with version 7.1. from provider with 1 application. I want to flash a normal os. but on all versions gives an error test device fail. I can not erase or write. how do i flash a box?
first you need the right Rom , for RK3229 with correct Wifidrivers ,
what stands on the Sticker ???
good luck / gefattern
Hi ,
Hi ,
what are this strange Cable on the Nand , this can cause the Error ,
no need for this to reach MaskRomMode , if possible , take it away ,
but maybe the Box is full bricked because of this ....
greetings / gefattern
this button for MaskRomMode. i tried whithout Cable, but not work. box new and worked. i cant erase or flash nand.
it must work without Cable ,
connect the Pins , with a small piece of copper cable or similar ,
hold it , connect Power , then you will hear and see connected in
MaskRomMode , now you can stop holding pins , after this you must
"restore" with correct Rom .
Maybe your PCB is fully bricked because it already fails the test Device ,
Hi ,
pcb new and working. button is soldered to the cable. I press it when I connect usb. then I release the button. I have flashed many times rk devices.. I think the bootloader is write-protected.
i think that this cheap Boxes build like that , if you try to flash other Rom , it bricks the
Loader or similar , somewhere is read that shorting the last two Pins of the Nand does
something special but not sure what and if it helps ??? , hope you find a Solution ,
Hi ,
Guest
Originally posted by charan View Posti have same pcb with prepare idb fail error
There are currently 1745 users online. 1 members and 1744 guests.
