Hello, I am using Ugoos AM6 Pro with latest 0.2.5 update. I am facing this issue:
If I shut down TV, all running apps for example youtube vanced, tune in radio etc... stop playing.
TV Box is connected via hdmi cable to AVR and from AVR to TV.
CEC in TV Box, AVR and TV is off.
The old TV Box T95Z PRO was able to run apps in android 7.1.2 after TV off.
Is there any possibility to let apps running after TV off with AM6?
Maybe try turning CEC on in in AM6 Settings - Display - HDMI CEC - Sleep device when tv off
Disable this setting while keeping CEC Control enabled.
I tried it, but it did not help. After turning off the TV, AVR lost connection with TV Box for few seconds. After few seconds signal is back.
Some apps notice lost of connection and stop playing. Not all apps stop playing, so it is maybe feature of some apps.
For example youtube vanced/deezer/spotify stop playing music and SmartyoutubeTV or Horizon Go continue playing.
So maybe the only one solution will be to block android to recognize lost of signal from AVR.
