Tronsmart Element T6 Max 60W Bluetooth 5.0 NFC Speaker SoundPulse™ 20 Hours Playtime Siri Google Assistant Cortana USB-C Fast Charge.
Highlights (From webpage)
360-degree Surround Sound
With the finely engineered position of 4 tweeters and 1 woofer inside, the T6 Max delivers a well-balanced surround sound to ensure that everyone can enjoy the equally excellent sound, from any angle.
Unrivaled Deep Bass
A custom-designed array of 8 passive radiators delivers monstrous sound along with the hardest hitting bass that you will not only hear but also feel it, even in a low level of volume.
SoundPulse™ Technology
SoundPulse™ technology delivers a 60W max output making every beat of bass more intense, more detailed, and more defined.
Elegant Craft. Iconic Decor.
Designed in a classic cylindrical form and crafted in premium aluminum alloy and fabric finish for a truly elegant look and feel. It's an iconic decoration in the house.
20 Hours of Playtime
The built-in rechargeable 12,000mAh Li-ion battery pack gives you up to 20 hours of continuous playtime on a single charge.
*On 50% volume level.
True Wireless Stereo
Wirelessly connect two T6 Max speakers for an extraordinarily elevated audio listening experience. Enjoy the true home theatre surround sound.
IPX5 Splashproof
With an IPX5 rating, the T6 Max stands up to sweat, splashes and rain.
Intuitive Touch Control
Integrated lighting touch panel offers convenient tapping control, and lets you easily recognize the buttons even in a dark room.
Personal Assistant
Access Siri or Google to check your calendar, schedule, alarms, reminders, and more from the speaker with a simple tap.
Wireless with Bluetooth and NFC
Play music wirelessly via Bluetooth or simply touch your NFC-enabled smartphone to the speaker and get the music streaming seamlessly.
Hi Guys,Thanks for taking the time to read this.My friends at geekbuying asked me if i wanted to test and review there new Wireless Bluetooth NFC Speaker.The Tronsmart T6 max has been a real joy to try out and has impressed me so much,With its Awesome 360-degree Surround Sound that sounds just as good from any angel.
There's no front and back just place the speaker in the required spot in your room,Garden or even the beach and you will get perfect clear deep sounds both trebbel and bass that really pump out the tunes like no other bluetooth speaker.
Ports and touch buttons locations
Its nice to see and to be able to use both USB C and DC charging ports that are covered by a rubber bung.The power button can still be pressed with out removing the bung dirt or crap in the charging ports.
At this point i would normally show you some internal photos but not this time theres no way im risking breaking this baby love it love it love it, Your going to have to make do with some pic's iv stole from geekbuying webpage.
The T6 max is no small bluetooth speaker (L x W x H): 140 x 140 x 193 mm / 5.51 x 5.51 x 7.60 inches and it has some weight behind it weighing in at 1.982kg / 69.91oz
If your in the market for a new bluetooth speaker i highly recomend this,I no you will love it as much as i do the sound is truly amazing with such deep bass and so clear.
3 graphic equalizer modes to pick from which includes Balanced,3D and deep bass.Each one can be selected by pressing the play/pause button for 2 sec
Full unboxing video
Specification
General
Model: Tronsmart Element T6 Max
Type: Bluetooth 5.0 Speaker
Color: Black
Specification
Bluetooth Profile: A2DP V1.3, AVRCP V1.6, GAVDP V1.3, HFP V1.7, HID V1.1, IOPT, SPP V1.2
Output : 60W
Transmission distance: 10m / 33ft (open area)
Frequency range: 40Hz - 20KHz
Radio frequency: 2.402 - 2.483G
S/N: - 65dB
Playtime: Up to 20 hours (50% volume level)
Battery: 12000 mAh
Charge input: DC 5V/3A, 24V/0.65A
Charging time: About 6 hours
Dimensions&Weight
Product Weight: 1.982kg / 69.91oz
Product Size(L x W x H): 140 x 140 x 193 mm / 5.51 x 5.51 x 7.60 inches
Package Contents
1 x Tronsmart Element T6 Max Bluetooth speaker
1 x USB-C charging cable
1 x 3.5mm audio cable
1 x Storage pouch
1 x User manual
1 x Warranty card
