TUREWELL T95 Max+ Teardown Pictures
akh, i c, no screw needed to open the case. btw, do you have link for firmware? i got a problem with this box.., sometimes when streaming, no sound output for around half second i think, not sure is the problem. i'm trying to root it, but, supersu incompatible with the su file... already try change cpu governor to performance, the sound output glitch still not being solved..
Sorry friend, No Firmware available yet. I tried their website and have emailed the support mail address but they haven't been in touch yet. I tried some generic USB/SD Card flash files but they wouldn't work. Most rely on a reset button but this Chinese clone doesnt have one. I agree with you with the performance though... it's terrible and needs a better firmware. Root would be great as I cannot seem to find a good Netflix APK to work on this box without spoofing the app into thinking that its a phone without root. If you find anything please let me know
I have same model (4/32), but looks like it is already rooted. I can use "adb shell" with root, and am able to modify files on /system partition by doing "adb remount". I am not trying any new firmware because I don't have the original firmware. Searched a lot on web, but not able to find it anywhere. I have done a full backup using TWRP, but I don't know how to convert it to AmLogic flashable package that can be used by USB Burning Tool.
SniperJunkie BTW, this box does have a reset button. That is how I was able to run TWRP. I inserted a thin stick inside the AV jack at the back of the box. It does have a button at the end of the jack. Keep the button pressed and start the box - it boots into stock recovery.- Copy TWRP_322.zip on a USB stick and keep it inserted in the box.
- Keep reset button pressed, and plug in the power. It will boot into stock recovery.
- Select "Apply update from EXT" and select TWRP_322.zip from USB stick. It will directly start TWRP. No need to install it permanently.
Originally posted by drsam007 View PostSniperJunkie BTW, this box does have a reset button. That is how I was able to run TWRP. I inserted a thin stick inside the AV jack at the back of the box. It does have a button at the end of the jack. Keep the button pressed and start the box - it boots into stock recovery.- Copy TWRP_322.zip on a USB stick and keep it inserted in the box.
Originally posted by sssolider2 View Post
can i install a custom firmware? which one is the best.
Spoke too soon.. Looks like someone got official firmware by asking the seller on Amazon:
I just use "adb shell" and do whatever I want as root. Why do you need SuperSU / Magisk?
There are currently 3487 users online. 0 members and 3487 guests.
