I did many tests: It's not for the wifi/ethernet, it's not for speed connection (I use a libreelec on raspberry and the stream is fluid without problem), it's not for the resolution.
Every xxx seconds stream has a little delay, but you recognize by eye. It's very annoying.
Since I want to use Android because I want to use some applications, how can I solve it? Is there any hack to do? Any system configuration? Thanks for your help.
