[ROM] MINIXFREAK OS ""2020 Update""
Originally posted by blindlf View Post
Originally posted by blindlf View PostTwo problems:
1. Volume bar disappeared, but a blank bar shows on the right side and disappeared after a while over and over again.
2. logcat cannot work: "logcat read failure"
i will be releasing V8 Soon builds are uploading ..... i just cant test gt1 mini builds but should work .... i fixed the systemui bug i hope so far it hasnt done anything wierd .... debloated a bit and mades soem tweaks as well Plus brand new amazing theme..... will keep everyone updated when all the builds upload
Originally posted by misufreak View PostHi minixfreak.
In your the latest version V8 it can be disabled DolbyVision?
I ask this because I have trouble with customized display settings, isn't preserved after reboot, and I solved this utilizing SC's firmware and disambling DolbyVision.
Thank you.
Tried to burn V8 with usb tool 2.2.0 and it stops at 14% tried two different usb cables 4 x ports lol
GTKing pro SA9H.
also can not flash back to std lol any ideas update now back to standard by sd card method
V8 Re-downloaded and also fails on 16% this time.
Originally posted by chenzen666 View PostTried to burn V8 with usb tool 2.2.0 and it stops at 14% tried two different usb cables 4 x ports lol
GTKing pro SA9H.
There are currently 1883 users online. 1 members and 1882 guests.
