i have made a custom rom for personal use atm, if anyone has problems with their tv box i could upload some img.
The ROM WILL NOT FIX
Netflix/Amazon Prime (No certification with this device)
Autoframerate in newer Kodi builds (only support RKMC autoframerate switching atm)
RKCodec is still broken
Youtube SD Playback glitchy AF (144ß, 240p, 360p)
Audio Passtrough not working
...maybe more bugs?
The ROM WILL FIX
Third party launcher crashing, can set any launcher
Wallpaper service fixed
working root with SuperSU (you know what happens if you update binary
Kernel is OVERCLOCK to 2GHZ
improve performance
build.prop tweaks
Fixed Overflow menu button missing from some apps (example Titanium Backup)
Fix Widgets not working correctly
Google Play Store fully working
Added Navigation Bar
Allow to open Dropdown Menu of Android using Navbar
WARNING: Kernel is OC --> Box may overheat,i recommend use FAN (i run at 40°C) or underclock using KERNEL AUDITOR
I am still in process of learning so i cannot fix every issue.
ROM FOR: Generic TV Box = WIfi "RTL8723", support 16GB ROM, 32GB ROM, 64GB ROM (untested 64gb!), support 2GB RAM, 4GB RAM DDR3
NO SUPPORT: IT6334, AP6255, no support DDR4 RAM
TV Box:
Mx9Pro
A5X Max
MX10
if you have rk 3328 box with kernel by "foxluo" and you have same hardware you may try to install
